Press the F8 key several times while it's booting and it should enter safe mode.
Read a comment by an expert who solved this issue ;-
Got it working again - it's F2 on the Inspiron 1501 to get into the
BIOS. Once I was in safe mode, I found a piece of freeware I'd
installed was causing the problem. I disabled it, tested the system,
then removed it altogether. Now my laptop's back to normal. Thanks for
your help.
Thanks.
Safe mode is appear on the screen before the normal windows system. all you have to do is press F8 or Function 8 before the normal system comes up. This procedure is only for technical assistance, whatever any changes on safe mode is your decision. Good Luck!
If you select F8 repeatedly, you should display the Safe Mode menu.
SOURCE: my dell inspiron is not working
its not a big problem,first don't panic.just follow the steps i m telling you-
when computer give options like safe mode,safe mode with net working etc.enter on safe mode
after that if windows starts thn run your antivirus installed in your computer and if u dont hav antivirus then install it using pendrive or cd and run it.
after full scan od the system restart computer again.
if problem persists then again start your computer in safe mode and cut all the importand data from your c drive and paste it on d drive or e drive and reinstall XP or VISTA but remember while installing XP OR VISTA computer will ask you to format whole computer or the c drive only,u only format c drive.
tht's it
and always have one good antivirus installed in your system and update it regularly.
cheers
SOURCE: My Dell Inspiron 1501 will
If you wish to go in safe mode, press F8 continiusly after Bios display.
Thanks
SOURCE: My dell inspiron 1501 with microsoft vista loops
Sounds like you may have a corrupt driver or incompatible software trying to launch at boot. Or, at worst, malware thats totally screwing it up. If you have access to another PC, download Service Pack 2 for Vista. Boot your PC into safe mode, and try to install SP2 from safe mode.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
