Ac/dc adapter not working where can I source a new one
Search for a Travel Laptop Adapter or Universal Laptop Adapter. Targus makes one with several different tips. Targus Laptop AC DC Travel Charger with USB Fast Charging Port USB...
SOURCE: AC/DC adapter
Make sure the voltage and amperage is the same and the tip fits.
I use I-GO universal from Radio shack
SOURCE: presario v2000 won't charge or run on dc adapter
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Page 205 should answer your question.
SOURCE: I have an ACER SPIRE 3680 2682, is bad, is not
If no lights, no sound then the problem with the Motherboard Power section Problem, like the DC pin is broken or any shorts etc etc. If Power light is On no Display then the problem with the Display video chip, have to reball the Chip or Replace the chip, service center's only fix this type of issue. best of luck
SOURCE: My Laptop won't power up
try plugging it to another same brand laptop. if the result is the same that means ur power adapter is faulty, if it's ok with other laptop then its ur laptop's power connector & motherboard is faulty
