SOURCE: My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
SOURCE: Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
SOURCE: dyson - can't push the vacuum
try to see if the carpet setting is to carpet. i know this machine says that its a life time belt,but i would check this just in case. best way to tell if it's working is to lay the machine on its belly with the brushes pointing up and turn on the machine to see if the brushes are turning. (be careful not to put your face directly in front, just in case something is lodged in the brush and flies out )
