Question about Toshiba Satellite Pro L300 Notebook
Toshiba l300 power problem
Laptop works fine with battery but goes off when power is connected
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
Check if the adaptor is working fine. Use a multimeter to check the voltage output from the adaptor.
If the adaptor is working fine, please add a comment to the question.
Posted on Aug 27, 2014
SOURCE:
  • 36 Answers
SOURCE: cant type @ key in toshiba satellite L300 laptop
you need to change the layout of your keyboard. "Regional Settings" in windows.
Check on http://en.wikipedia.org/wiki/Keyboard_layout what your layout is and configure the correct one in the operating system you are using
Posted on Aug 11, 2009
  • 86 Answers
SOURCE: Configfree problem in Toshiba L300
go to network connections and look for the wireless connection and start it that way
Posted on Oct 19, 2009
darkpain
  • 316 Answers
SOURCE: tryin to locate the cmos battery in a Toshiba L300
Turn off the laptop and pull the laptop batteries first, use a screwdriver to open the cover screw
After open the cover, and then slowly pull the cable red-black coil , which is the CMOS battery cable connecting the laptop to the board.
But make sure that you know what your doing because you can cause problem to then battery,motherboard or worse!!
Posted on Feb 05, 2010
ic0729
  • 212 Answers
SOURCE: my toshiba satellite L300 has no power
Please follow these steps VERY CAREFULLY:
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
Posted on May 03, 2010
umhhmm
  • 67 Answers
SOURCE: toshiba satellite L300 laptop sound drivers on XP do not work
try going to there web site and down loading driver and install.good luck
Posted on Jun 16, 2010
I have a Toshiba L300, when ever i connect the Adapter Chager, the laptop freezes and it give me a blue screen background (not BSOD). The laptop' working fine when it's running on battery powe
It sounds as if you need a new charger. Try removing the battery and start the machine with just the charger. If that works then it may be a new battery you need. Some toshiba notebooks have a 'power saver tool' preinstalled, which is used to monitor battery performance. You can download a copy here:
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
Not sure if it will be compatible with your machine, but maybe worth a try as it could be a corrupt program causing the problem.
Mar 29, 2012 | Toshiba Satellite Pro L300-EZ1004X...
Toshiba satellite l300 not charging, doesnt work on the power supply
Try removing the battery completely and running it with the power supply connected. If that doesn't work, try borrowing a compatible power supply, or buy a universal one, and try with and without the battery connected.
The problem may be the power supply, in which case the battery won't charge and the laptop won't get any power.
Apr 06, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that...
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Mar 22, 2011 | Toshiba Satellite Pro L300 Notebook
TOSHIBA SATELLITE PRO L300: PSLBDG : PROBLEMS: 1) Restarts automatically when i plug in the power cord. However works fine in Battery. 2) Shuts down when i try to install graphics driver after a clean...
Replace the AC Adapter, (ebay from £10.00).
Did it come with XP on it? Mine came with Vista and there are conflicts with XP and graphic adapters. There is no XP driver for the ATI adapter in mine.
Go online to Toshiba and download all of the updated drivers that you require. A user friendly system.
Dec 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on my l300 laptop and the power supply is connected to AC power my laptop will automatically turn off. what is the posible problem of it?
plz try by removing the battery and connect it to ac. if the laptop is working then u have to check your battery, if the problem is there then it will be better if u take it to service centre
Aug 11, 2010 | Toshiba Satellite Pro L300 Notebook
My toshiba l300 can't even power.the led lights are not coming on.i have tasted the charger and it's working
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jul 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
My Toshiba Satellite PRo L300 won't shut down.
SIMPLY REMOVE BATTRY AND POWER SUPPLY
reconnect them
go to power options and check setting
"when i press power button"
select shutdown
May 05, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
