Samsung DVD-VR375 DVD Recorder/VCR Logo
A
Anonymous Posted on Aug 26, 2014
How to set up samsung dvd/vr375 recorder to Att-uverse box
Can not get recorder to record, but may need a 4 digit code
5 Related Answers
Anonymous
  • Posted on Aug 24, 2008
SOURCE: Problem connecting Samsung DVD-HR737 DVD recorder to Set Top Box
I had the same problem, if you go through the channels from your DVD-R remote it should give you the option AV-1 and then AV-2 ? on mine it's AV1 (test it out first and you have to watch what your recording) then it should record from the cable box
worth a try?
Anonymous
  • Posted on Sep 19, 2008
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Anonymous
  • Posted on Mar 02, 2009
SOURCE: Playing a recorded dvd from dvd-vr375 on another dvd player
If you are using DVD-R media, you can record in either V or VR mode.  What is confusing is that if you try to format the media, you only have the choice of VR mode -- and this mode is very well understood by other dvd players, some other records do understand it.  This mode has much better editing capability, but poor compatibility.  If you want compatibility, use the V mode.  The trick is that to do that, you don't format it!   V mode is the default and does not require formatting.  The owners manual says that, but too well hidden if you ask me
Anonymous
  • Posted on May 26, 2009
SOURCE: hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
Anonymous
  • Posted on Dec 30, 2009
SOURCE: cannot record copy protected message
OLD FBI WARNING USED TO ALLOW YOU TO MAKE BACKUP COPIES BUT THEY CHANGED IT KNOW THAT NOT EVEN THAT'S ALLOWED
OLD FBI WARNING DID NOT WANT YOU TO SELL, CHARGE FOR WATCHING BASICALLY MAKING A PROFIT OFF YOUR COPY
NOW YOU CAN NOT EVEN MAKE A BACKUP FOR YOURSELF
HBO, SHOWTIME, ETC ARE MOVIES CHANNELS SO IF YOU RECORDING OFF THOSE CHANNEL YOU ARE TECHNOLOGY COPYING ILLEGALLY
1helpful
I need philips universal 4 digit remote codes
Not sure I can help. You might do well to call Samsung 800-SAMSUNG. But I have the codes that should work if you were hooking the Samsung to a Philips set top box or cable box. Perhaps they are the same? (And how lucky are you that you landed this jewel! I love this unit!
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
1helpful
I am trying to record with VHS from TV and not using a cable box. No results. How do I do this?
This unit doesn't have a tuner. So unless your TV can provide video out (not a common feature) to the dvd/vcr recorder, you need a tuner. A set-top tuner box for OTA would work. With a little work, you could also use a tuner (USB or PCI slot card) in a computer. Usually you need a converter box unless your video card can output in a non-RGB format. The manual for this device is available here: http://www.samsung.com/us/support/downloads/DVD-VR375 .
I wish that I could be of more help.
2helpful
2answers
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
3helpful
2answers
Hookup wrong? I can't get the menu to come up for the VR375
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
2helpful
Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
