Computers & Internet Logo
A
Anonymous Posted on Aug 26, 2014
Wireless not connectd firewalled
Net
Noah Denza
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Sep 02, 2014
Noah Denza
Contributor
Level 1:
New Friend:
Answers
35
Questions
Helped
8267
Points
66
I would troubleshoot your connection to see if it could fix the problem.
I cant view my Local area connection and wireless connection in network connection.. how can i fixed this problem..but i am connectd in LAN connection
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
1helpful
2answers
Motorola router nat not open for xbox live
Configuring the Firewall for Gaming
By default, the SBG900 firewall is disabled.
If, as recommended, you enable the firewall, refer to the game’s documentation to ensure that the necessary ports are open for use by that game.
The pre-defined SBG firewall policies affect X-Box LiveTM as follows:
LOW: XBox Live data can pass through the firewall. No user action is required.
MEDIUM or HIGH: To enable X-Box Live traffic to pass, you must configure:
• Choose Custom on the Firewall > POLICY — basic Page • UDP 88:88 and UDP/TCP 3074:3074 on the Firewall > POLICY — advanced Page
Configuring Port Triggers
Because the SBG has pre-defined port triggers for games using any of the following applications, no user action is required to enable them:
• DirectX 7 and DirectX 8 • MSN Games by Zone.com • Battle.net®
For a list of games supported by Battle.net, visit http://www.battle.net.
You may need to create custom port triggers to enable other games to operate properly. If you set custom port triggers and enable the firewall, you must customize the firewall to allow traffic through those ports.
To create custom port triggers, use the Gateway > PORT TRIGGERS — custom Page.
SB900 USER GUIDE
The motorola guide has more information relating to port triggers.
If you download the pdf file, go to page 27 for Firewall settings and Page 35 for Gaming Settings..
More indepth information is there.
Hope that helps
Mike
Netgear wireless router keeps scanning; what is the problem? I can't connect
I was also facing the same problem. My sygate firewall was blocking the USB adapter from connecting to the net.
DWL 520 D Link Wireless PCI
disable the firewall and check the configuration of the ap
WIRELESS CONNECTION.
First you need to purchase or aquire a wireless router which can send out a wireless signal. Be sure to bring you laptop to the store to ensure you hare busing a router which emitts te right frequecy.
for example, there are laptops whihc have a 802.11b wiress adapter and thos which have a 802.11n whic only works on on a 802.11 n frequency, so please be sure to check with the sales person.
Also, if you are goin withing 100 fee from the router for just in appartment or upstairs or down stairs you will not need a high end system. You may want a middile of the road option no more tha $75 for the router.
You would simply plug in the wireless router to the ethernet cable. It will come with software which would walk you though instructions on how to enable your wireless net card on you laptop and to detect and secure your wirteless router.
Hva e fun.
Kwame
2answers
Wireless conection with xbox 360
does it have a firewall built in on the belkin?
im assuming it has a port blocked on the firewall settings.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
