Question about Siemens SpeedStream Modem (4100) (SS4100)
Siemens Speedstream 4200 Driver
I have a Siemens Speedstream 4200 Modem and am trying to get the drivers for this, am putting in http://192.168.254.254 in the address field as I was originally instructed to when I first received the modem but I can't seem to access it now. Do you know where I can get the drivers for this modem? I was with a different ISP when I last used this.
Regards, Debbie
  • 6 more comments
  • Anonymous Apr 10, 2008
    I had similar problem till I found out the modem only works when its is Bridge Only mode, with PPPoE.
  • Anonymous Aug 27, 2008
    I cannot find the cd that came with modem and i need drivers
  • Anonymous Sep 02, 2008
    would it be possible to use the USB port and the Eithernet port at the same time, Eithernet port is for a desktop and USB port is for a portable, would that work?
  • shyfox47 Sep 06, 2008
    i dont have the downloads to get on internet
  • sumitkr76 Dec 23, 2008
    I can't find drivers for this modem on the siemens website!!!
  • Anonymous Dec 24, 2008
    I need help with a 4200 speedstream
  • fleckles Jan 10, 2009
    I have installed driver_usb_4200 but cannoy get any modem interface... What is wrong?
    Kevin JCJD Symons
    fleckles@lizzy.com.au
  • Anonymous Feb 04, 2009
    I can not connect to my vpn connection
  • 65 Answers
OK, we are all not dumb. the question is where are the drivers. Just go to www.hankscomputerservice.com/SpeedStream4200driversxp&vista.zip for both the drivers for XP & VISTA, or get everything ells you want from http://www.thevoipstore.net/speedstream-4200.php
Posted on Feb 18, 2009
Posted on Oct 28, 2008
    Problem Solver:
  • 17 Answers
Drivers are available on the manufacturers website:
http://www.siemens.com/index.jsp?sdc_p=lo1272700umc9dnsfp
ISP supplied units sometimes come with customised firmware which blocks port 5060. To remove the block, replace you firmware with a non-customised version.
To configure the modem, type http://192.168.0.1 in the address field.
Posted on Nov 09, 2007
At the bottom of your modem, you can find the drivers...try to use http://192.168.0.1
Posted on Feb 20, 2009
Http://modems.nokiasiemensnetworks.com.au/BridgeMode.htm
you can look for the SpeedStream 4200 driver installer at this link, just look for the for the drivers link at the side of the page...
Posted on Sep 02, 2008
  • 36 Answers
You dont need drivers for this modem under vista or XP
* Open up your internet explorer, in the address bar type 192.168.0.1
* You can see the configuration page here. In the login page, enter the email address password to go online
Take care
Posted on May 26, 2008
Kujktjjdyujydjtyjhn
Posted on Oct 30, 2008
Steveaug,
You need drivers for this modem if you connect it by USB. Yes, it should be connected by ethernet, but if you don't have the right cable, you can't.
Posted on Aug 26, 2008
    New Friend:
Download in http://gigaset.com/br/pt/pages/index.html
Posted on May 30, 2010
Well the site modem support .com.au seems to have some answers for Vista still looking up Win 2000 and XP get back to you when I find anything.
Posted on Dec 08, 2008
  • Anonymous Dec 08, 2008
    Goto an internet cafe or a friends that will let you down load file off modem support.com.au I hope this site will help at this site Vista drivers for USB and the manual.
    Roy
6ya staff
SOURCE:
I have a siemens speedstream 4200 and windowsXP.
Are you connecting the modem using a USB cable or a ethernet cable.
If its the USB cable you would need the disk supplied with it and if its an ethernet cable, no installation is required.
regards
Sandeep
Oct 19, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Driver
Drivers are not needed. Just connect your PC to the modem with an ethernet cable. The modem should give the PC an IP address. Open a browser and in the address window type in 192.168.0.1 and you should see the setup screen for the modem.
Jun 07, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens speedstream 4200 modem need any driver?
http://gigaset.com/shc/0,1935,us_en_0_14791_rArNrNrNrN,00.html GO HERTE RICHARDM69
Nov 18, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Speedstream 4200
I keep get a NAT type 3 on my ps3. I've been told when plugging the modem straight into the ps3 it should be type 2. After looking on the net it seems that there is some type of problem because of the Speedstream 4200 Modem. Is there some type of setting I could change on this modem to make it better?
Sep 04, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Siemens speedsteam 4200
you need to log on to portforward.com shoose router, choose game then follow instructions on how to open port 10400    to 10499 as well as udp 3658                       Adnan
Jan 05, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Help me
PROBABLY HAVE TO GET AN UPDATED DRIVER, GO TO THE INTERNET AND TYPR IN SPEEDSTREAM 4200 VISTA DRIVER
Dec 18, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Visit this link http://www.modemsupport.com.au/. On the left side under the heading Speedstream 4200 download and isntall both the drivers and firmware.
Once you've installed the firmware open iexplorer and goto http://192.168.254.254 . Type in an admin password and save settings. Type in your username and password ( provided by your isp ) press save again and then press connect. you should be in business.
Nov 09, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Siemens SpeedStream Modem (4100) (SS4100) Logo
53,820 people viewed this question
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
