Went to turn on my coffee maker and nothing lights up or turns on
SOURCE: manual for Mr Coffee Bread Machine
http://www.foodsaver.com/manuals/MrCoffee/5810%20Breadmaker%20Recipe%20Book-color.pdf
there is a link for the mr coffee breadmaker
SOURCE: I need instructions for cleaning my Mr Coffee
Vinager and water are great for cleaning your coffee machine just run the mixture through the machine as you would just plain water as if you were making coffee. It might take three run throughs to clean it well, some may suggest bleach however, it takes a few rinses to get that smell out and it tends to transend to your cup. Not a happy java experience.
You will mix it 25/75 vinager/water just plain white will do, nothing fancy. It works has worked for a long time. For at least 50yrs that I know of...
SOURCE: my coffee maker wont turn on - it's plugged in & power is on.
Hello cutecuddles1,
I have a possible solution for you. Sometimes the unit will not work when the stick filter is blocked. A sensor shuts down the unit until corrected.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used an eyeglass screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
SOURCE: A couple of days ago, coffee maker turned it self
spoke w/ Cuisinart. Unplug unit for 1 hr, then plug back in, reset clock & Auto Off setting. This resets the unit back to the factory settings.
Testimonial: "great it works!!! thank you so much!!!!!"
SOURCE: Brand new Mr coffee PSTX
If you look where the reservior fits into the base, specifically where the water goes in, there is a rubber seal. It's held in by a circulary plastic piece and 3 screws. I took it apart there to see if something was amiss and decided after looking at it some that they had put the seal in upside down. So I put it back together with the lip of the seal facing up instead of down and I have not had a single drop of water leak from the reservior again. Now if I can get the thermos pot that came with it to stop leaking every time I pour a cup I will be a happy camper.
