I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any
Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
need to know the steps on connecting the bluetooth to the phone
my jabra bluetooth will not connect to my samsung phone. i do not have the code to the bluetooth.
I have a razor that will not find my jabra BT then phone keeps saying "no devices found..........
I have a problem connecting my Jabra BT185Z to my phone. Please provide the pass key.
I can get the headset to work with my incoming and outgoing calls, but not with the mp3 player.
i was also given a had me down blu-tooth, my phone is a moto w755. i am unable to get it into the pairing mode. the blue light flashes but does not stay on, and my phone cant pick it up, i even took it to the verizon dealer. the person that gave it to me then told me to contact you..for help (help).
