Exercise & Fitness Logo
H
Hassan Posted on Aug 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to find a safety key for TX1 kettler treadmill
Kettler Marathon TX1 safety key
Thomas Smithbrother
Level 3:
Top Expert:
  • Master 3,698 Answers
  • Posted on Aug 26, 2014
Thomas Smithbrother
Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
956973
Points
10318
Www.kettlerusa.com/fitness
1 Related Answer
anupam19
Anupam Datta
  • 263 Answers
  • Posted on Mar 12, 2011
SOURCE: The running belt on my kettler marathon tx1
Use grease and check if any lock is there
Kettler Marathon ST threadmill stuck on blinking HR
If your Kettler Marathon ST treadmill is stuck at the blinking HR (heart rate) screen and is unresponsive to button presses, here are a few suggestions you can try to troubleshoot the issue:
  1. Check the safety key: Ensure that the safety key is properly inserted into the console. The treadmill may not respond if the safety key is not properly engaged.
  2. Reset the treadmill: Locate the power switch or unplug the treadmill from the power source. Leave it unplugged for a few minutes to allow the internal electronics to reset. Then, plug it back in or turn the power switch back on. This can sometimes resolve temporary glitches or errors.
  3. Inspect the console connections: Open the console cover and check the connections between the console and the rest of the treadmill. Make sure all cables and connectors are securely plugged in. Loose or disconnected cables can cause communication issues and affect the functionality of the console.
  4. Clean the console buttons: Over time, dirt, dust, or debris can accumulate around the console buttons, preventing them from registering presses. Gently clean the buttons and the surrounding area using a soft, lint-free cloth. Avoid using liquid cleaners that could damage the console.
  5. Perform a console reset: Look for a small reset button or hole on the console. Using a paperclip or a similar object, press and hold the reset button for a few seconds. This will perform a console reset, which may resolve certain software or configuration issues.
  6. Consult the user manual: Refer to the user manual or documentation that came with your Kettler Marathon ST treadmill. Look for specific troubleshooting steps or contact information for technical support.
Kettler Toronto treadmill - The display says Safety and the treadmill wont work. The safety key is not unplugged.
Question moved from MISC.
I live in Toronto!
Try removing the key and reinsert it.
The KETTLER treadmill has an emergency stop mechanism for
your safety. Before starting your workout, fasten the cord of the
safety key to your clothing. If the treadmill has been shut down
by removing the safety key, restart it by reinserting the key. An
automatic restart of the treadmill belt does not occur. Further
instructions concerning the handling of the safety cut-out can be
found in the operating instructions for the training computer.
https://manuall.co.uk/kettler-toronto-treadmill/
How to fix Err 94 on Treadmill Kettler TX1 ?
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
My kettler tx1 marathon running machine causes the electricity to swith off in the house. This occurs when I start the treadmill, not when I simply switch it on. Any idea as to the cause?
The motor or the Motor control board is faulty. Can be the motor brush or the shorted igbt transistor in the motor contol board. If you wish to get some more details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
High speed and error 91 and treadmill stop
Please recalibrate the machine with software calibration, for easy diagnose, troubleshooting and fix it
If the problem persist, you must need some basic parts or need service for repair. See hte block diagram attached.
God bless you
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email [email protected] or www.kettler.co.uk
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
