The copies won't print because transfer came out
The primary transfer is not on the drum it is located across from the drum as the paper goes between the drum and the primary transfer assy. and or roller (sponge looking roller), then reinstall the transfer assy..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Sharp 2700N has gray bands on copies
Hi
be very careful you could cost your self allot of $
If the grey band moves it could be 1 of 2 things 1st try cleaning the fuser section be careful it is very hot, and if you not familiar with this you may want to find a service provider, it can get a little tricky, 2nd it could be the Drum cleaning blade and the drum need to be replaced. if you take the drum out this also can be very tricky. It sounds also like it may just need to be cleaned like the mirrors and platen.
Good Luck
