Question about Kaz Air Purifiers
How to take it apart - Kaz Air Purifiers
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Jul 22, 2014 | Electrolux Band Aerus Lux Legacy Canister...
Take it apart
I had the same issue. What I found upon taking it apart was that it must have fallen and the case was not making contact with one of the safety switches. Taking it apart was easy a mix of phillips head screws and torx screws. Took me 15 minutes to take apart and find the bad spot. I hope your fix is this easy.
Jul 07, 2014 | Oreck XL Professional Air Purifier
How do you take apart a Vicks 3700 humidifier and clean the fan?
Hello Judith,
Here is a Youtube video that should help you clean your humidifier.
If not exactly search through Youtube for more specific details. You may find many helpful videos with proper search, but be sure to watch video completely to be sure it is the task you are trying to accomplish.
PEACE
Kaz com How to clean warm mist humidifier
May 25, 2014 | Vicks V3700 Starry Night Cool Mist...
Won't turn on
Might be a fuse BUT it is enclosed in the unit. You would have to take it apart to see. IT could also be other parts in the power supply that have failed, With that in mind, if you do take it apart, take pictures so that you can put it back together.
Aug 27, 2012 | Sharper Image Ionic Breeze 3.0 Air...
How do you take the unit apart?
I work for the Ionic Pro Company. Please call customer service at 800-875-8577 and they will walk you through the steps. Thank you, Mary
Dec 19, 2010 | Ionic Pro 901P2RIP04 Air Purifier
How do you clean the ionizer in a lasko wind curve
You have to take the fan apart. They didn't design it with the convenience of the customer who likes to keep things clean in mind, so you have to get out a bunch of screwdrivers and stuff and roll around on the ground and fight with it until you get it apart. I posted a lengthy post on how to get this model apart, as I just did mine yesterday. Just look for my name on the Lasko models like this one. But be careful and don't try it if you don't think you can pull it off without getting hurt.
Jun 11, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Living Air Model XL-15C: the red-neon FT ionizer bulb does light.
Corrosion in the cicuitry at the connection are unseen until you take them apart, can cause this. The male and female connectors might be together but rotted inside the boots unseen and not connected. That happens sometimes. Gently pull those connections apart and look inside both connection areas and check.
Apr 28, 2010 | Ecoquest Fresh Air Air Purifier
Ionic Breeze Midi Prof. Plus has red light on and won't work
When you cleaned everything did you also turn the whole unit upside down and gently shake to remove trapped dirt in the bottom of the unit. As for taking this unit apart to clean throughly there is no need. Just use some q-tips with 91% Isopropal alcohol not Rubbing alcohol to get to the small areas. Pay close attention to the small arrow shaped metal contact near the bottom of the unit. Make sure it is wiped clean and everything is completely dry. Plug unit back into power and the red button should turn green.
Mar 22, 2010 | Sharper Image Professional Plus Ionic...
Cigarette smoke from my neighbor's apartment...
I hope your not allergec to pets or something else in the new place.If it is the smoke do not hesitate, invest in air purifier/electronic air cleaner.They work great in filtering smoke but need cleaning often.
Mar 15, 2010 | Air Purifiers
Thanks and
On this model both sides should come apart. The ioniser plate is glass with metal in it. Soak in dishwashing liquid sollution and rinse thorothly with fresh water and dry completely. clean the contacts that attaches to with a emory coth or very light sand paper. While you have apart inspect all wire connections and if you see a pc board look for any burnt marks. I could not access your email but mine is eboukater@gmail.com.
Sep 28, 2008 | Sharper Image Professional Plus Ionic...
Air Purifiers Logo
51 people viewed this question
Top Kaz Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Kaz Air Purifier Expert? Answer questions, earn points and help others
