Alesis Sr 16 Stereo Drum Machine Logo
A
Anonymous Posted on Aug 25, 2014
Mpg yellow oval
Crate TX30E Taxi/Yellow Battery-Powered Amplifier. Lights up but no sound? Crate yellow amplifier.
Question edited for clarity (with a guess at model).
Question moved from Television and Video.
If you want to check inside it, look for damaged components or blown or bulging capacitors. The best solution is to take it to a local electronics or audio store for repair.
https://www.google.com/search?q=crate+yellow+amplifier+no+sound
Peavey pv 1200 Amplifier no sound the yellow leds stays on help
WHEN THE YELLOW LED IS ON ALL THE TIME, IT MEANS ITS ON PROTECTION MODE MEANSNG IT HAS A FAULT. U NEED A TECHNICIAN TO CHECK AND CONFIRM THE FAULTY COMPONENTS.
On headstock the numbers are pressed as follows: 122 84264 the same numbers are on the inside written on label and pressed on the other end of the neck seen only inside the oval sound hole
You didn't say what instrument you're asking about, and various manufacturers use similar systems. You need to tell us the make and model. In addition, you haven't asked a question.. What can we help you with?
Apr 13, 2016 • Music
Horn wiring diagram
Yellow is positive, yellow/black is negative.
Feb 19, 2014 • JBL Music
Which wire yellow or blue goes on red post
Peavey color indicates that Blue is Negative And Yellow Is Positive, so Yellow goes to + Speaker Terminal.
I cant find the echo part on the mixer for karaoke
The effects or FX section is on the top right of the mixer. On your vocal channels find the yellow knob marked FX and turn it to 0. Choose the effect you need using the Program knob (top right) for karaoke this will probably be 03 or 06. Start singing and turn up the yellow knob marked 3 - FX under AUX Sends until the LEDs above them hit -0db, no higher.
Now find the button marked FX - Main Mix and make sure it is UP.
Turn up the yellow knob (3 - FX) next to it until you can hear enough echo on your mic.
I need to replace the speakers. i need the speaker
Just giving the dimensions isn't going to get you the rright speakers. Many of these have different impedance speakers than common ones. You best go to Casio to find the specs or the replacements. You did NOT even give us the model number of your unit. Contact Casio support and parts to get correct units.
Jul 26, 2011 • Casio Music
I need to find SOME kind of adequate replacement tweeter or dome or horn for a Yamaha MS150 powered speaker. (used for instruments or PA) The only specs i have are: The back of the magnet reads...
That is a very wide range cone type (oval) type tweeter that probably covers from around 2500 Hz up to 20KHz. You will probably NOT be satisfied with generic speaker... this one is special for sure. Try calling http://www.speakerrepair.com/ocsdiaphragms.html and see if you can get it reconed. Most speakers that are cheap will NOT take the power that the amp will deliver.
2helpful
Blue and yellow cables. Which one is +?
The consense is that the yellow is positive... However, if these come from a 1/4 inch jack, the color that connects to the TIP of the jack is the positive one..
I put a new speaker in my amp but don't know what wire is positive the blue or the yellow
Usually the yellow will be positive... Hint, it won't make a difference UNLESS you drive two of these in parallel as it only affects the phase of the cone movement relative to the input.
Connect the yellow to positive and don't worry about it further.
Top Alesis Music Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Alesis Music Expert? Answer questions, earn points and help others
