I AM VERY DISAPPOINTED WITH MY DACOR DOUBLE OVEN, IT SEEMS EVERYTIME I USE IT , IT NEEDS REPAIR . I SELF CLEANED IT WONT HEAT PAST 160, I HAVE SPENT OVER 500.00 IN REPAIR COST THE THREE YEARS I HAVE OWNED IT. IT IS A VERY EXSPENSIVE PEICE OF ****. I WILL NEVER BUY ANOTHER DACOR PRODUCT AND I AM GOING TO REPLACE IT WITH A CHEAPER GE MODEL, WHICH BUT THE WAY I OWNED ON FOR 22 YEARS AND REPLACED IT BECAUSE WE REMODELED OUR HOME . A 5000.00 LEASON LEARNED
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
