This viking has 2 diff buttons for front jets and back jets,, front button is lite but jet doesnt come on. other button when pushed jet does work.. any idea
SOURCE: one side of jets not working + pump cuts off too
JET MAY BE PLUGGED . SNAKE IT WITH A CLOTHS HANGER.OR GARDEN HOSE. THIS MAY BE YOUR PROBLEM WITH THE MOTOR SHUTTING OFF. ITS CALLED DEAD HEADING .THIS MAKES THE MOTOR WORK REAL HARD= HIGH AMPS=HEAT+EVENTUAL MOTOR FAILURE OH AND HIGH POWER BILLS AS A ADDED BONUS. CHECK POWER CORD THESE UNITS MUST BE CLOSE TO THE POWER SUPPLY
SOURCE: I have and old sequoia spa that works great except
If the jet button is an air operated one, you can try to unscrew the button assembly and possibly reconnect the air tubing to it. Some air buttons come apart from the top, some from underneath.
SOURCE: Intermittent jet problem on Spa form hot tub
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
This sounds like a back circuit board to us.
rod
uspartscenter.com
I need a manual to program the controller, how do I get one?
