Water is spilling over into the pipe and causing the toilet to flush
SOURCE: My Pressure Assisted toilet does not have the power to flush
Found this on this same site...Please let us know is it works (I'd like to know since I'm considering a pressure-assisted toilet).
Solution #2
posted on Apr 21, 2009
Asker's Rating
nanotick
Rank: Apprentice
Rating: 0%, 0 votes
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
SOURCE: We just replaced out toilet because we had no
its got a blocked down pipe lime scale will do this to you, the only way to sort it out is strip it out completly and give it a good clean, if that still failes to flush then its the flushing pump needing looking at,
SOURCE: Flushing problem with American Standard toilet model 2474
American Standard 2474016.222 also had the same problem mine had two discs apparently on efrom factory perhaps and one from the floating disc that must have fallen off I used a screw to get them out adn drained as much water as possible then went back and forth adding water a little at a time and then using a tolwel to sponge the water out (no shop vac around) After findign one I then found the other. This post saved me sooo much money adn I have dealt with the intermittant problem for years in this spare bathroom THANK YOU SO MUCH
