Question about Sea-Doo US 2010 GTX 155
How to replace starter relay wiring diagram for 2010 GTX 155 sea doo
Can't remember which way relay fits in bracket and wires connect to new relay?
I have a 2004 sea doo with a starting problem. It will turn over 3 or 4 times and then just click. I have a new battery and have cleaned all terminals within reach.
Perhaps.
I suggest you test the theory by bypassing the relay and/or energising the starter motor manually using a jumper lead, a suitable screwdriver or similar or a remote starter switch.
Mar 19, 2017 | Cars & Trucks
2010 Patriot won't starter key works lights horn new starter & battery checked 30 amp fuses starter
WHAT ????? want to try again .
2010 Patriot won't start ,key work's , light's ,horn ,new starter and battery ! checked 30 amp fuse's starter ?????? Maybe you should take it to a qualified repair shop .Sounds like you have no clue.
Feb 01, 2017 | Cars & Trucks
Sea doo troubleshooting
have you checked the intercooler isnt leaking water into the air intake while running ?
Jul 21, 2014 | Sea-Doo US 2004 GTX 4-TEC
96 seaboo will not go full speed in water, but full rpm out of water
carbs need cleaning and check the pulse jet that squirts fuel on set off , fuel pump diaphrams ok ?
Sep 08, 2013 | Sea-Doo US Seadoo sea doo cdi ignition...
1988 sea doo
have you checked the starter button is working and fuses and wires clean and no breaks in wires ?
Jun 28, 2013 | Boating
How do you replace the Gas Strut on a Sea Doo GTX 155
pop the clips off then fit the bottom first then lever it on the top carefully !
May 11, 2013 | Boating
2003 dyna starter turns but wont engage, new battery fitted
Hi Anonymous, lift up rubber boot on positive cable to starter, unplug starter relay wire usually green, with a jumper wire connected to positive battery cable starter stud, touch blade connecter on starter where starter relay wire was removed. If starter engages and turns over engine then your starter relay is bad. If starter activates but does not engage then your starter drive/clutch is bad. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 22, 2012 | Cars & Trucks
What are the steps to change a Kia Sedona Starter
The starter can be removed from under the vehicle. But before doing anything,first disconnect the negative terminal of the car battery.Do start the procedure with battery connected. The starter is located on the frame rail on the driver's side. Lift the car up on jack stands.Give proper support to the car before working under the car to locate and remove the starter.Now before removing the starter you will have to remove the upper intake manifold bracket .This manifold bracket is held by 4 screws,remove those screws first to loose the upper intake manifold bracket.Then remove the wiring connections from starter solenoid mounted on the top of the starter motor.There are two wiring connectors remove both.Both the wiring connectors are fitted by a nut.Remove both the nuts and loosen both the wiring connector.Now loosen the starter connecting bolts and remove the starter carefully from the engine compartment.In the reverse procedure reconnect the new/replacement starter and complete the procedure. ------- Keep updated for any more queries.Thanks.
Oct 14, 2010 | 2003 Kia Sedona
Sea-Doo US 2010 GTX 155 Logo
256 people viewed this question
Top Sea-Doo US Boating Experts
Richard Lilja
Richard Lilja
barrybam
Andrew Taylor
Andrew Taylor
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
