Motorola Mobility H700 Wireless Headset Logo
Lisa Michelle Posted on Aug 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why can't I be heard with my bluetooth n136 linked to my phone?
I have linked it to my Samsung Focus Windows 7 phone and can hear people but they can't hear me.
  • Motorola Mobility
    Motorola Mobility Aug 26, 2014
    Hi Lisa Michelle, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Lisa is the image posted to the left of your question the model you have or does it look different? I don't recognize the N136 as a model of ours. Mark Motorola Support
  • Official Brand Answer 3,100 Answers
  • Posted on Aug 27, 2014
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684871
Points
13487
Lisa-
If your headset is a Motorola headset we recommend you CONTACT US
Mark
Motorola Support
5 Related Answers
Anonymous
  • 239 Answers
  • Posted on Mar 06, 2009
SOURCE: Need to pair up my BLUETOOTH # N136 headset with my Razr V3 phone
if you need the code it should be 0000
could also be
6789
9876
4321
1234
9999
hope this helps
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Anonymous
  • Posted on Feb 12, 2009
SOURCE: Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Anonymous
  • 827 Answers
  • Posted on Dec 22, 2008
SOURCE: HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Anonymous
  • 52 Answers
  • Posted on Sep 08, 2009
SOURCE: Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
vanherringto
J. Van
  • 1738 Answers
  • Posted on Feb 04, 2010
SOURCE: Need directions for N136 bluetooth device not
Your headset may also be called a HS850. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
Want to pair my new Samsung sgh a687 Strive phone with my Motorola n136 bluetooth. When I try to do this, the phone says it cannot find it. Thanks.
Try to remove the battery of your cellphone sometimes it has to do with the radio interference connectivity. Or try to find another phone to check if your bluetooth can paired with other cellphone models. To see if your blutooth features has a problem.
Jun 18, 2011 • Cell Phones
1helpful
2answers
I have this motorola n136 that I used with my old Samsung phone. Then I bought a new samsung and bought a new charger for the blue tooth and now I cannot synch the two together.
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>>>>
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
4helpful
Hope this helps
Chris (ziraffa)
5helpful
How to connect the bluetooth??
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual: http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
2answers
Bluetooth help
turn on bluetooth in both the phones
in anyone of the phone try searching for new devices.
it may ask some code for pairing of both the devices.
after giving the code ,both the phones ll be enabled to send and receive the files in both o them..
Jun 16, 2008 • Cell Phones
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
