Question about Pride Celebrity X 4-Wheel Electric Scooter
Can you identify fault codes 1&3
Codes displayed even when throttle pot is disconnected
  • Pride Master
  • 2,478 Answers
It will tell you in the manual. If no manual,go to Pride on online, download a free manual.
Posted on Jan 19, 2015
SOURCE:
I have a pride go go ultra x scooter... I purchased it, and it had no top dash at all... I put a new throttle pot, and a whole new dash assembly... It runs great... Then I turn the speed pot to fast......
7 flash code is: Throttle control fault.
1. Check wiring for open/short circuits.
2. Check the throttle set-up.... The ohms should be very close to each other when placed checking forward and reverse on set up.
Aug 24, 2014 | Pride Mobility Products GoGo Ultra X...
I have a IMC Heartway Gypsy and the power light blinks 5 times and the scooter won't run. I have just replaced the batteries. Is there list of what each code means? Thanks
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
May 18, 2014 | Pride Mobility Products Go Go Ultra X 3...
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
Apr 04, 2014 | DSC Home Security
Where is diagnostic plug 1992 range rover
As far as I can recall, some earlier Land Rover vehicles relied on reading LED flashes (or LCD display) from the vehicle's ECU computer itself, so try the following:
Locate the engine ECU (possibly hidden under the one of the front seats - remove carpet or cover; or behind the left hand kick panel). Once you have located the ECU and it has LED's or a display, do the following procedure:
1) Run engine up to operating temperature
2) Place gears in PARK or Neutral and turn ignition OFF & wait 3 seconds.
3) Turn ignition to position "II" (do not start) - Fault code will display
Note: repeat steps 2 & 3 to obtain any additional codes
4) If no codes display, then disconnect the White 5-pin connector plug (located behind r/hand underside of dash)
5) Repeat steps 2 (wait 3 seconds) & 3 again to see if codes display.
Feel free to post your codes here and someone will be happy to advise you further.
Cheers,
Jun 07, 2011 | Land Rover Range Rover Cars & Trucks
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
6=RF Jam Detected
8=PC5204 AC Failure
2=Loss of AC Power
Aug 09, 2010 | DSC Power Supervision Relay For Smoke And...
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
I have a Nissan Frontier with accelerator & throttle problems. I have sensor codes p2122 & p2138. How do i fix this problem? Is it a self fix problem? HELP!
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
P2122 - APP Sensor 1 Low Input
Probable Causes:
1 - Failed APP Sensor 1
2 - Open or short circuit condition
3 - Poor electrical connection
P2138 - APP Sensor Performance Condition Fault
Probable Causes:
I hope this helps you and thank you
Feb 14, 2010 | Nissan Frontier Cars & Trucks
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
Pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Apr 24, 2009 | Drive Medical Mini Phantom Three Wheel...
Pride Celebrity X 4-Wheel Electric Scooter  Logo
132 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
