When you push the power button the fans starts but next to it is a long beeping sound which then stops and another long beeping sound is heard. is it the memory card??
SOURCE: repetitive beeping sound on startup - no pc response
check this link for beep problems
http://en.kioskea.net/contents/pc/bios.php3
SOURCE: Acer Aspire T690 startup problem
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
SOURCE: no display no beeps but cpu is fine,power led is on and fans are running
Have you upgraded the memory?
SOURCE: Dell E510 Memory
I deal with this sort of thing alot with servers. Easiest thing to try first is reseat the memory.
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
