SOURCE: masterbuilt 7 in 1 gas smoker
here is the pdf format link, hope this helps :)
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
SOURCE: MASTERBUILT GAS SMOKER
Here is the link for the maunel online in pdf format
the main website says individual parts will be availible for sale soon, main website is
http://www.masterbuilt.com/index.html
hope this helps
SOURCE: Need instruction on how to season masterbuilt electric smoker
soak some hickory/ oak / mesquite chips any one of these will do, soak them in water for a couple of hours then put them in the pan and turn it on this will burn out any coating on the metal and flavor the grill for smoking leave it on for a good 2-3 hrs on med then on high mke sure you keep the chips replenished
SOURCE: Do you know of a good recipe book that works with masterbuilt smo
If you really want to learn the art of smoking and slow cooking food, Google "smokering" Lot's of forums and helpful people to get you started. Lots of smoker recipes also.
SOURCE: used the masterbuilt smoker only 5 times???
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
[email protected]
Masterbuilt's website has manuals in pdf format. Although the English manual for the ESQ30B isn't listed, it is available for download:
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20ESQ30B.pdf
