Turn the key and it doesn't turn over but just clicks
Also make sure the connections at the battery are not corroded. Pay attention to the dash lights, are they dim? Or do theu jist shut off totally when you crank it.
Several possible causes. 2 most likely. Battery voltage is not sufficient to turn the starter motor, in this case, try using jumper cables. Or the start itself could be bad. The click is likely the starter solenoid pushing the starter gear up into the flywheel, but the starter motor is not turning.
Worst case, this is also the symptoms you would receive if the engine was froze up.
