Question about Lenovo IdeaPad Yoga 2 Pro
I have a lenovo yoga 2 pro and I recently bought a brookstone Pocket projector pro. I hooked it up as directed but could not get an image. All I got was no signal. I played with the settings and selec
I know the projector works because I tried it on a friends laptop and it works without a hitch.
    Top Expert:
  • Lenovo Master
  • 30,503 Answers
Did you enable VGA output?
Posted on Aug 25, 2014
SOURCE:
birky09
  • 104 Answers
SOURCE: I have a Lenovo 3000 N100 Note book that
have you installed all drivers of your laptop with xp compatible? better download it from lenovo site the drivers for windows xp.
Posted on Dec 07, 2009
Testimonial: "Thanks!"
kurtis_1318
  • 382 Answers
SOURCE: SIR I HAVE LENOVO
>What is the model of your Y510?
>First make sure that the model of your computer is the one with TV Tuner on it (Y510 with model number 7758-44Q has a TV Tuner on it)
>If you do make sure you installed the driver compatible with your Operating System
>if you look at this link:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=12
>it will show you 2 drivers for the TV Tuner one compatible with Windows Vista 32bit and Win XP
>If you are sure you have downloaded the one for XP then just tweak the settings of yuor TV Tuner and look for LIVE TV.
these are just tips and not a total resolution to the problem but still your comments suggestions ratings and testimonials will greatly be appreciated
Posted on Sep 23, 2010
SOURCE: I have a Lenovo Ideapad with a built in Lenovo
Hi kstrong,
I see that you need driver installed on you system, since you reinstalled windows on your Y510, make sure you check device manger on your system to see what driver you my need to install or probably you may need to reinstall all the drivers to make everything work fine on the Laptop.
below is a link where you can download your driver for your Y510 Laptop. http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=12
Once in the Download page make sure you only download the driver that is for the exact Windows on your system, it will say on the right side of each driver indicating what windows the driver is for.
I hope that this helps you with your concern, Reinstalling all your Laptops drivers will fix your systems devices and make them work properly again.
thanks have nice day.
Posted on Apr 09, 2011
jhoeldorz
  • 169 Answers
SOURCE: how do i get the images to a projector from my lenovo?
If you are using a Windows system. You can just press "Start Menu"(windows logo) + "P". It is the hotkey for using a projector. It also applies for other video devices connected to your unit.
hope this helps.
Posted on Jul 20, 2012
Geekman
  • 32281 Answers
SOURCE: Lenovo Yoga Touch screen Quad core tablet has no sound
Check the MUTE setting has not been set on the speakers.
Check the Volume setting, move to a higher volume level.
Try re-installing the Audio driver.
Posted on Apr 13, 2013
I am borrowing projector 1625073 from a friend but i dont know how to connect it to my labtop please help
Please start with the make and model of both the projector and your laptop. Without that, we have no idea what cable and/or adapter you might need. 1625073 doesn't mean anything to me, it's really of no help.
Apr 29, 2016 | Office Equipment & Supplies
I have a master cycle and i need the hitch
I found something on amazon, here: Amazon com master cycle hitch. I hope I have helped. Cheers
Jul 14, 2009 | Cycling
No video stream
driver problem so try to install it from their site
Jun 21, 2009 | Toshiba Satellite A85-S107 Notebook
Monitor Display on TV
Try the following:
Power up the projector first. With the laptop hooked up but not powered on once projector is warming up begin booting laptop. If there is still no display once its projector is fully warmed up and laptop booted you can try using the (fn) key with the laptop monitor switching function key usually F4 which switches the display monitor to show on external, external and laptop or just laptop. If this all fails try changing resolution of laptop to something that might be more projector friendly.
Let me know how you go.
Mar 23, 2009 | Dell Inspiron 6000 Notebook
Want to know the towing capacity for our truck
First off the 1997 F-250 HD with a 4.10 rear end will haul 14,900 lbs. The real question is do you have a receiver hitch or the rear bumper hitch. If you have the rear bumper hitch buy a receiver hitch that mounts to the frame a class 5 is usually put on these trucks. However a class 4 will work just fine for 6,000 lbs. The receiver hitch will have the capacity stated right on the hitch you just bend over and read it. It will give you two ratings one with weight distribution device and one without. You will be looking at the one without. That will fall somewhere between 6,000 and 12,000 lbs depending on the hitch manufacturer and the class. Hope this helps.
Mar 20, 2009 | 1997 Ford F250 SuperCab
SL53S PIII
I have just fitted one to my IX250, works perfectly and even throttles down when full power is not needed.
May 07, 2008 | Itronix GoBook IX250 Notebook
Connecting without the cd
Yes, but you'll still need the drivers. The disk that came with the printer originally had the dirvers on it.
The drivers without the disk can be found at this link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305961&lc=en&cc=us&dlc=en&lang=en&cc=us
You'll need to know what operating system you have, but that should work without a hitch. Let me know if you need any more help!
-Ernest
May 02, 2008 | HP DeskJet 3535 InkJet Printer
Use of Monitor Output Socket
Most of the Vaio's use <FN> <F7>
Apr 23, 2008 | Computers & Internet
Acer Laptop problem with LCD Projectors
I have the same model of Acer and it worked in all of my classroom LCD with powerpoint lectures and with a SONY TV at home. Try right-clicking your screen to view the NVIDIA control panel. Configure "dual" multiple display (costumize to "dual" configuration or "forced-detect."
Jan 09, 2008 | Computers & Internet
Open Questions:
AVIRA Te-cH SuPport ~~18OO8-O31.O69 PhoNe NuMbEr A.V.C.S This AVIRA USA phone number is ranked #2 out of 2 because 7,728 AVIRA USA customers tried our tools and information and gave us feedback a fter they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVIRA USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AVIRA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVIRA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVIRA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVIRA USA Calling AVIRA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVIRA USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVIRA USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVIRA USA's phone numbers against each other. Contacting AVIRA USA in General While I8OO8O31O69 is AVIRA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVIRA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVIRA USA.
Oct 16, 2019 | Avira Computers & Internet
BITDEFENDER Te-cH SuPport ~~18OO8-O31.O69 PhoNe NuMbEr A.V.C.S This BITDEFENDER USA phone number is ranked #2 out of 2 because 7,728 BITDEFENDER USA customers tried our tools and information and gave us feedback a fter they called. The reason customers call # I:8OO:,:8O31069 is to reach the BITDEFENDER USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.
Oct 16, 2019 | BitDefender Computers & Internet
See all Lenovo IdeaPad Yoga 2 Pro Questions
Lenovo IdeaPad Yoga 2 Pro Logo
162 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
