Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
SOURCE: Whirlpool duet Model ghw9200lw
The errrors are generally related to one another. The "F02" error is a slow drain problem. The "SUD" gets generated because it senses air in your drain pump (due to a possible blockage). More than likely you have an obstruction in your drain pump and you will need to clean it out. This is probably the reason for the pump sounding strange too. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Follow the link provided and this should be a an easy process for you. Keep in mind, however, that if there has been something obstructing your drain pump for any significant length of time, you may have damaged to pump. It doesn't take much to cause irrrepairable damage (I know, its a crappy design). If you clean out the drain pump reservoir, and the error(s) reappear, you will have to replace the drain pump.
If you require a replacment pump, you can purchase a new one on line at searspartsdirect.com. Just type in your model number and the pump can be located under the "Pump and Motor Parts" heading as item number 10 (part #8181684). For instructions on how to replace the pump, follow this link:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Hopefully, it won't come to the point of replacing the pump, but you have the information if you need to. I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: error code F02 on whirlpool
Pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business.
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
SOURCE: whirlpool duet washer will not spin out water,
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
Potential Causes
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
