Microsoft Xbox 360 Console Logo
A
Anonymous Posted on Aug 24, 2014
Why is my Xbox 360 not detecting the 250 GB hard drive.
Not sure how it happened ,but the format currently is NTSC. it needs to be fat32. Is exFAT the same filing system as FAT32 ?The problem I am having is the console is not detecting the hard drive.
5 Related Answers
Anonymous
  • 34 Answers
  • Posted on May 26, 2007
SOURCE: Movie Formats To Work With Xbox 360
As you may have heard, with the Xbox 360 Flash Fall 2006 System Update they are adding support for WMV video playback from new sources. Videos can be streamed from a PC running Windows Media Connect, Windows Media Player 11, or the new Zune client player, and can also be played from Optical Disc and most USB mass storage devices. For all these sources, only the WMV video file format and codecs are supported. How do I know if a video file will work on the Xbox 360? Currently only the Windows Media Video (WMV) file format and codecs are supported. If you have a file with a ?.wmv? extension, then the odds are pretty good that it will work. Technical details on the types of files we support can be found at the end of this post, but the easiest way to find out if a file will work or not is to just try it. Hopefully after you click play the video will show up on your display, but if the content is not supported you will simply get an ?Unplayable Content? message blade from the side of the screen and then be returned to the Video blade. How do I create videos that will play on my Xbox 360? Windows Movie Maker, a standard feature of Windows XPSP2, will output WMV video files compatible with the Xbox 360 console. Either use the default settings when you finish a movie and click ?Save to my computer,? or just make sure that the output video format you select shows the file type as ?Windows Media Video (WMV).? Videos will usually look best when they are closest to the original resolution that they were created with. Try to create video files at least 360 pixels high in vertical resolution in order to minimize content upscaling on the console. If you decide you want finer control of the output video file format, download a version of Windows Media Encoder (http://www.microsoft.com/windows/windowsmedia/) and then start encoding away. Optimal size and bitrate settings will vary depending on the source material you are encoding. As a general guideline though, 1.5 Mbps is a typical bitrate that should be suitable for most standard definition content, and 8 Mbps is a common bitrate for high definition content. Can I get more technical details about the kinds of files you support? WMV video files with the extension ?.wmv? are stored in a generic file container format known as ASF. ASF files can contain many different types of codecs within them. Xbox 360 supports most common WMV video codecs, as seen in the following chart: Supported Video Codecs: Name FourCC Windows Media Video 7 WMV1 Windows Media Video 8 WMV2 Windows Media Video 9 WMV3 Windows Media Video 9 Advanced Profile WVC1 There are some files with ?.wmv? extension that may play on a PC, but are unsupported on the Xbox 360 console. Windows Media Screen, Windows Media 9 Image (Photostory), and some older Microsoft codecs are unsupported, as seen in the following chart: Unsupported Codecs: Name FourCC Microsoft MPEG-4 Video Codec V3 MP43 Microsoft MPEG-4 Video Codec V2 MP42 Microsoft MPEG-4 Video Codec V1 MP41 Windows Media Screen V9 MSS2 Windows Media Screen V7 MSS1 Windows Media Video 9 Image WMVP Windows Media Video 9 Image v2 WVP2 ISO MPEG-4 Video V1 MP4S Anamorphic content with nonsquare pixels is currently unsupported on Xbox 360 console, and will be displayed as if the pixels were square. If you want to play such content on your console, it is recommended that you re-encode the content in a square pixel format.
Archeangel
  • Posted on Mar 01, 2008
SOURCE: 360 drive only reads dvds, not xbox 360 games, just says put in an xbox 360 console.
You need to flash the drive with the old drive's key; otherwise the your xbox motherboard will not allow that drive to access the gameplay engine and will not allow you to play games.
Anonymous
  • 6 Answers
  • Posted on May 13, 2009
SOURCE: Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
Anonymous
  • 50 Answers
  • Posted on Jul 03, 2009
SOURCE: Game Won't load With Hard Drive in, But will Without harddrive
look for any corrupted file on your harddrive, instead of a normal icon for a file, it will show a yellow triangle and an exclamation point in the middle, delete it..
after that clear cache, to do this go to system settings, memory,
press y for device options, if you can see the rename and format option in the screen, you are in the right screen, press x, x, left bumper, right bumper, and then x, x, select yes,
even though you cannot see any corrupted files in all of the folders in the harddrive, you have to clear the cache..
if this doesnt work try deleting the saved game content to that specific game..
Anonymous
  • 340 Answers
  • Posted on Jan 29, 2010
SOURCE: Update failed when starting up brand new xbox!?
You can download updates to a cd rom,then try to update it that way,
Google, downloading updates to console.aspx.
Remember thumbs up if this helps.
Testimonial: "Hard drive is fine. Must be the corrupted update, called MS and they are making sure it will work when i send it back...again."
Cannot complete full format, it take more than 8 hr and at 99 % complete it stops and says "format not complete" , (it works when doing quick format but iam unable to use the drive on my ps3, and...
Welcome to Fixya. If you want to use the drive to your PS3 Console you can still do a Quick Format on the Hard Drive but make sure you select Fat32 File System type to be able for the Ps3 to detect the hard drive. Make sure you use Windows XP or Windows 7 on formatting the hard drive to Fat32 because Windows Vista dont have Fat32 it uses ExFat.
Thanks for using Fixya.
3helpful
2answers
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
1helpful
3answers
If I format the drive/erase, will I loose all the files I was able to save there? I can't copy my iPhoto onto my Iomega because it says "cannot be modified." If I format, will I lose all the...
if you format the drive you will loose all the data on the drive. save the file on a different computer before you format it. later you can transfer them back. (please rate me if this helps Thank you)
I have an external hard drive (300gb) that I want to convert to FAT32 it is currently unformatted and windows only gives me the option to convert to exfat or ntfs and neither are of use to me. How can I...
You cannot format FAT32 on such a big drive unless you break it up into many, many, suitable partitions, to format a drive this size you MUST use NTFS....
You see FAT32 simply cannot mathematically address that amount of address space, it is just that simple.
The biggest size partition is 32 squared or 1024MB
10helpful
Hi, i can't download some files to my transcend elite storejet 500GB, it's says the file is too big, but the file is just 5.49 GB and free space in hard drive is more than 400 GB. what to do?
You drive is formatted for FAT32. What that means is the way data is stored on the hard drive is an older method that does not support files over 4GB. The benefir of FAT32 though is it can be read and written in both Windows and Mac. If you hate mac (as we all do) then screw FAT32. I almost forgot, if you use this hard drive with the xbox 360 do not continue as the xbox 360 for some ******* reason 360s can only read FAT32. The new format we are going to go to is called NTFS (new technology file system) which is made by microsoft, makers of the xbox 360. lol
Anyway first backup everything you have on that disk. Either on a computer or burn it to DVDs cause if you don't you will lose everything.
Plug in the drive, right click on My Computer (or its just "computer" now) click manage. Go to disk management on the left pane. It will take a minute to detect all your drives. You will see your 500gb drive. Double and even triple check it is your transcend drive. Right click it and click format. Change File System to NTFS.
2helpful
When plugging in to xbox 360. it doesnt recognise the hard drive so i cant play films or music
If you have the latest elements drive, it may be formatted to NTFS. The Xbox 360 cannot read NTFS, so the simple solution would be to format it to FAT32. The problem, would then be that you cannot transfer files larger than 4GB or a folders with more than 1000 files to a FAT32 drive.
Hope this helps
1helpful
4answers
Wd passport will not load to my xbox 360
Re: My passport Elite 500 will not show up my Xbox360 Options 12-30-2009 11:19 AM
if it's the drive that comes with the smartware, then it comes pre-formatted NTFS , and your xbox needs FAT32 format to work.
So, you need to connected this drive on a mac computer to format to ms dos FAT32, or use a formatting utility like "partition magic" to format the drive to fat32, then if there's password assigned remove it, and it should work
4answers
XBOX games on XBOX 360
You must have an Xbox 360 Hard Drive to play original Xbox games on your Xbox 360 console.
You can only play approved original Xbox games on Xbox 360. Visit the following Web site to view a current list of approved original Xbox games that you can play on Xbox 360:
http://www.xbox.com/games
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
2answers
Maxtor 3200 external hard drive
Make sure the drive is formatted for the appropriate file system.
Keep me posted.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
