Product code zdt12011fa, zanussi dishwasher beeps once and end of cycle light flashes
SOURCE: FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
SOURCE: i have a cda mx194
MX194 Dishwasher.
Switch off and unplug before doing anything. .
First three lights are flashing on top and it will not stop making stupid noises.
Remove plastic panels at front of machine under door, see if there is water inside.
If there is ... something is leaking. If it is a slow leak - solution is to dry up excess water in tray with paper towels or whatever comes to hand. You will need to find the leak somehow - salt container is usual suspect.
There is a microswitch attached to a float on the left hand side inside a white plastic cover. Water at the base of this activates the switch and disables machine. Mine has not leaked since trying this fix and machine is running well 2 months down the line. Better 10 minutes with paper towels than 2 hours of expensive plumbers.
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
SOURCE: IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
