I'm looking for a solution to a light switch problem I am having with the stairwell that goes from the main floor to the upper floor in my home. Currently, I have an occupancy sensor (It is a 3way) on the upper floor facing the stairs. At the bottom of the stairs, I have a toggle switch. The way the switches work right now is that if the toggle switch is in the "on" position, then the occupancy sensor at the top of the stairs works fine. If the toggle switch is in the "off" position, then the occupancy sensor does not work (i.e. won't turn the lights on). What's wrong ????
SOURCE: A fixture on a Lutron Maestro dimmer switch stopped working.
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
SOURCE: I have power running to a 2 switch gangbox. Each
You will need the fallowing materials 12/2 wire, enough to go from the existing two to the top of the stairs were you are putting the new switch. You will need a single gang remodel box also called old work. One switch, and wire nuts. You will need a flat and philips screw driver and wire strippers/cutters.
First disconnect power to the existing switches.
Remove the two switches that are in the box
Locate the two black wires that go to the lights. one will be for one half and the other for the other half of the basement. these are your switch leg wires mark them so you will know what they are
Locate the other black wire from each switch. these are probably pig tailed into one wire in a red wire nut. the wire nut will have three black wires in it. You will disconect the two wires that went to the switches. Keep the pig tails you can use them later
Next you will find a wire nut with three white wires twisted together. remove the wire nut and untwist the wires.
You should have three bare copper wires. usually under a green wire nut. these should also be conected to each switch. again take these twisted wires apart.
Next you will run the new 12/2 wire from this box to the new single gang box. Cut the hole for the new box using the box to measure your hole. next bring the 12/2 wire into the new single gang box.
secure your box to the sheetrock.
Take the insulation off of the wire and expose the white black and bare copper wires.
Put the black wire on the bottom screw of the new switch and put the white wire on the top screw and finally the bare wire on the green screw. make sure your wire is secured well to the switch
Screw the switch to the box and install the cover to the switch.
Next go down the the two gang box here were are going to make the top switch take over these two.
Take the black that the two switches pig tailed into and put this and your new black wire together with a red wire nut. use new nuts
Next take the white wire from your new wire and connect it to the the bottom screw of each switch. you may use the old pig tails you took off of the old switches and be sure to use new nuts
Next connect the black wires that were at the top of the old switches back on the same way.
Next connect the ground wires all twisted together. you may need a larger wire nut our you can pig tail three and two.
Put both switches back in the box and install the cover plate
turn the electricity back on to the switch box and you will be able to walk up stairs with both lights on and turn them both off at the top but make sure you turn them back on when you reenter the basement or neither one will work below. Once you have turned the top switch back on though they will both work just like before.
hope this helps
SOURCE: I have 2 lucent light switches that broke I need
You will have to replace the entire switch. If they are not to old sometimes they will exchange them out for a new one
SOURCE: i AM REPLACING A 3
The other switch should only be changing from one wire being hot when it is in the up position to a second wire being hot when it is in the down position. Then the new dimmer should be hot on one terminal when the other switch is up and on a different terminal when it is down.
I'm not sure how the Leviton dimmer works, though.
Gary
SOURCE: I installed a Lutron LG
The correct way to wire this switch is the wire that was on the gold or dark colored screw of the old three way switch is called the shunt or common terminal. The wire connected to this terminal is to be connected to the black wire of the three way dimmer. The other two wires are connected to the silver or light colored terminals of the switch. These are the traveler terminals. The traveler wires may be connect to either traveler terminal - it does not matter which.
If you have already disconnected the old switch, simply connect the dimmer wires to the house wires as shown top to bottom in each configuration below until you get it to work as expected:
Config1 Config2 Config3
B R R B R R B R R Dimmer Wires: B = Black R= Red R = Red
R W B B R W W R B House Wires: R = Red W= White B= Black
In two configurations or less, you'll have found the correct wiring for the switch. I hope this helps & good luck! Please rate my reply. Thank you.
