SOURCE: Hi, I have a leviton
You said they are 50 watt GU10's, so I would assume they are 120V halogens, and you must simply have gotten a bad dimmer. But if these GU10's are 50 watt equivalent (LED's or CFL's) then the bulbs will have their own transformers built into them, and would be incompatible with a dimmer switch. It also might be the case that you have low voltage halogens which would use a transformer, shared or individual, and these would also be incompatible with a dimmer. (I don't know offhand if GU10's are available with low voltage halogens.)
SOURCE: I have leviton 6681 dimmer
That range seems a little small, but I think still within reason. The reality is that dimmer manufacturers consider the basic rotary dimmer to be the red-headed step-child of their product offering. They offer it because they have to, not because they want to - and as such, typically dump as little money into the quality of the product as possible.
SOURCE: I have a 600 watt 1 pole Diva dimmer controlling
First of all, in general, dimmers (even at their highest setting) cause the lights to dim even a little bit. If you are doing a 1-for-1 comparison, you may notice a difference - but honestly, it shouldn't be THAT dramatic that you're able to notice it.
My first suggestion is to double-check the model number. There's a version of Diva with a "G" in the model number (DV-603PG-) which was designed with a lower-high-end light level than normal (designed to guarantee extra energy-savings).
If the model number checks out, my next suggestion is to upgrade to a spec-grade product (like an NT-600-WH). The commercia/specification grade products have a higher high-end than the residential grade products. It still will dim the lights a little bit, but will be better.
After that, I suggest calling tech support at 1-800-523-9466 for more suggestions. Its a free call and they're available 24/7.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
