Did you fix this issue? I am having the same problem and I cannot seem to complete the sequenceDid you fix this issue? I am having the same problem and I cannot seem to complete the sequence
You can't post conmments that contain an email address.
NOTE: this will only work on the earlier models with the SCPH 1000 bios 22/9/2004
1. Press and hold Circle , Right and L1 2. Press and hold L3 and push the stick hard 3. Boot into the PS2 browser without a CD/DVD in the tray 4. Press circle and R1 on the DVD 5. Hold right until an menu appears 6. Press circle and R1 again.
If this fails try this
1. Load the DVD into the PS2 that you want to play. 2. At the browser screen select the CD icon press and hold circle and square until the DVD menu appears. 3. Either select the movie select icon or the play icon.
If these two fail you will need a Messiah chip OR magic chip 2 installed
You have the unit wired wrong. When you shut your key off the radio loses ALL power and it needs ACC power to maintain the memory. If not, the unit will reset itself. The screen you see is the touchscreen calibration screen. Just follow the " X " around the screen to 5. Then the unit will boot up again. You will have to reset radio stations and EQ and speaker settings. If you don't fix the ACC wire, you will have to do this A LOT!
ok here is the big secret. There should be a wire that goes to the parking break. In most after market radios, it is a brown wire. The way to get around this is to put that wire directly to ground. It will work at all times.
I have a similar Lanzar unit. I had it in twice while it was under warentee for the same issue. I also had it in a couple more times for other issues. It cost me about $30 shipping both ways each time I returened it. About a month after the warentee expired, the DVD quit ejecting again.
Bottom line, I would look at purchasing a different uint or use an ipod instead of the CD.
