RCA Sta-3900 Stereo Receiver Logo
A
Anonymous Posted on Aug 24, 2014
I have an RCA STA 3900 stereo reciever that wont turn on. Standby light is on. Tried resetting it from the back but didnt work. Please advise
Billy
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 89 Answers
  • Posted on Nov 24, 2014
Billy
Expert
Level 2:
New Friend:
Night Owl:
Answers
89
Questions
0
Helped
19915
Points
117
A standby condition can mean a fault in the receiver. voltages in the system are off. This can either be a bad diode or power transistor.
1 Related Answer
Anonymous
  • Posted on Feb 26, 2010
SOURCE: RCA STA-3900 standby light on will not turn on
POWER SUPPLY BLOWN FUSE CAUSED FOR A BLOWN OUTPUT TRANSISTOR , DO YOU HAVE THE NUMBER OF THOSE TRANSISTORS??
Need RCA Sta-3900 schematic diagram
Did you ever find the schematics? I am also troubleshooting my STA 3900.
Volume is not working
Sounds like your output transistors are bad, what audio you are hearing is coming from the driver transistors. Could be any number of thing else going on. Try selecting only one channel " a or b" at a time and see if the volume increases. It could be that your speakers have gone bad .If you have other speakers I would try that before taking it to a qualified repairman.
Where is the fuse
Unplug the unit,wait approximately 5 minutes,remove the top cover look for the place where the power cord enters the unit.the fuse will be on the board next to the power transformer, should be labeled F1 and a 4.5-5 amp 125/230v glass type fuse
Power won't stay on, keeps turning itself off after only 2-3 seconds
it is either a short on one of your speaker lines or it could also be that one of your PCI's have blown.
While trying to install an aftermarket radio the wires curcuited or blew now my dash lights and stock stereo wont work
you might have blown out all your electrical under your dashboard you might want to check your fuses in your car.
2helpful
I have a problem withmy RCA sta-3900 am/fm stereo receiver . The standby light is on , but when I turnthe power on , it stays on for 2-3 seconds then turns itself off . Thank you
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
