Screen on my tab 3 10.1 rotates upside down and left,right but will not rotate back to normal? please help
SOURCE: Screen Rotation
you have to drop the device back to its native resolution 800x420 for the rotate function to work
SOURCE: How do i install java for the samsung galaxy tab
Even though Android is based on Java, you cannot just pop in a .jar file and play it. It needs to be in apk format, short for android package(i presume). You need to first transfer the file to your sd card and use a file manager to find it. then click + install. I suggest ASTRO (file manager)
SOURCE: The Galaxy Tab could not
slide the drop down menu from the top of the screen (where the time and battery icons are) and click the 'Auto rotation'. that should do the trick. Cheers.
SOURCE: My galaxy do not rotate anymore...what do I do?
Try pulling down the notifications drawer (drag down on the status bar at the top of the home screen and ensure that Orientation Lock is not selected (if there is no toggle in the notifications drawer, try downloading an orientation lock widget from the Market and toggling that on and off to see if that fixes things.
Other than that, you might want to have the device checked to ensure that the sensors are still functioning correctly.
Hope this helps,
Alistair
SOURCE: samsung galaxy tab 2 10.1 wgxa model GT-P5113 is frozen
Hold the power button down for up to 15 seconds. This should hard reset it. Not to be confused with erasing data.
