Don't know anything I can add to above
Sure you, can a schmetic of what.
freon loop
mech, parts
elect. schematics??? electronics controls. , air controls
this is called a FSM. ever heard of that>?
here it is , read the HVAC pages then the wiring chapter same topic
why not post symptoms and let me tell you how to diagnose AC.
HVAC
click TJ here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
bingo. the whole 100 pages. on one topic, or more.
if you dont know HVAC, why not just post the symptoms..
the FSM is for savvy mechs. with HVAC training.
im good on the electric side, and can also tell you if the loop is failing.
but im not a Freon LOOP guy, i do electronic controls of all kinds.
retired, now.
SOURCE: 1994 jeep wrangler reaer differential oil
It should be just 80/90 gear lube unless ya got a locking diff but most just take 80/90
SOURCE: how to change starter on 1994 jeep wrangler
is it the straight six? if so first disconnect the battery then there should be 2 bolt 13 or 14 mm. take wires off. then reverse for install.
SOURCE: 2006 jeep wrangler check engine light came on it
There is a software update for the PCM that addresses this issue. TSB 18-028-06
SOURCE: I can not find the flasher relay on my 2006 jeep wranger?
remove shroud around signal and wiper switch,and it is between them
SOURCE: 2006 jeep wrangler oil leaking from the front of the transmission
the problem with the leak is the rear main seal on the engine is blown and should be replaced and you can pick one of these up at any auto parts store
