You would need to create a bootable USB stick, and then use tools installed on it to format your drive. full instructions Create Bootable USB Flash Drive
SOURCE: windows xp not recognising any hardware e.g.Pendrive,bluetooth
check are your usb driver is properly installed or they are enabled... I happed with me also... It took some time to locate and install the usb by windows but it can also be the cable problem... Check these things and if nothing is wrong within these then try to reinstall the windows and i am sure that this will solve your problem!
SOURCE: MY USB(2.0) PORT NOT WORKING
hi,
welcome to fixya.com,sir if u have already uninstalled and reinstalled the drivers and if u have already reinstalled the operating system and if it is still not working then simply replace the system motherboard.
SOURCE: how can i install xp service pack 2 by pen drive
You can use unetbootin. It's very easy and self-explanatory to use.
SOURCE: install windos xp sp2 from pendrive
ok this should be simple, While your computer starts to boot, before windows screen, keep pushing F2 to enter the bios setup. Set it to boot from usb first under boot order. Also make sure boot from usb is enabled under advanced
SOURCE: How do I format a disc (DVD or CD) on Windows XP?
You only format a CD/RW or a DVD/RW, which are re-writeable.
Regular discs do not need to be formatted (CD-R or DVD+R, DVD-R, DVD+R DL, etc.).
To format the DVD/RW idisc, use the "burner" software ( Sonic?, Nero?) and choose [Tools] [Erase Disc] (erase is the same as format)
Testimonial: "Thank you I will follow your instructions"
