Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
If the iPod will not turn off, try to reset it. Press and hold the
Sleep/Wake button and the Home button at the same time for at least ten
seconds, until either the Apple logo or battery symbol appears. If the
battery symbol appears, continue to charge iPod touch until it is fully
charged.
Itmaybe a battery problem...if you think its not a battery problem,you may want to try a software upgrade/restore...if your software version is already the latest one,backup all the ipod contents before you restore...you will find the restore option in the summary tab in itunes.
Press and hold the Home button for at least six seconds, until the application you were using quits.
If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
My 16gb touch just did the same thing, what i had to do was open up my ipod in itunes and restore it to its original settings. it will take some time to reset all your settings and resync all u'r music and applications but it worked for me. good luck!
it looks like in all of these cases it's either a battery or a motherboard issue, both can be replaced by a tech savy user or friend if you use an iPod touch repair guide, the parts are readily availabe on ebay.
