Hyundai 2007 Santa Fe GLS Logo
A
Anonymous Posted on Aug 24, 2014
Anythink library Variable Camshaft Timing Solenoid Connector
What does the code P0013 mean
The meaning of p0013
Intake camshaft position 'B' actuators circuit open bank 1
Possible causes
Variable camshaft timing (,VCT) CIRCUIT Open or short
vpwr circuit open
variable camshaft timing (VCT) solenoid open or short
Image of 2007 Hyundai Santa Fe Variable Camshaft Timing Solenoid Connector
need more imfo please need to know more what is wrong ?
Variable cam timing adjustment sensor how much does it cost and how long does it take to replace
camshaft actuator solenoid cost about $100.00 the camshaft actuator solenoid located on upper front part of the timing chain cover front of the camshaft. you have to remove top engine cover then remove air intake duct and air filter housing then remove engine mount strut bracket.
I have a 99 escort zx2 with an idling issue. I know this is common with some of these vehicles. I had a 1998 and never experienced this problem. Was a great car and sold it when it hi 450k. I'm...
VCT solenoid ????? IAC - idle air control valve . YOUR Vehicle has an IAC valve . Your vehicle does not have a VCT solenoid Variable Cam Timing
Variable Camshaft Timing is an automobile variable valve timing technology developed by Ford. It allows for more optimum engine performance, reduced emissions, and increased fuel efficiency compared to engines with fixed camshafts. It uses electronically controlled hydraulic valves that direct high pressure engine oil into the camshaft phaser cavity. These oil control solenoids are bolted into the cylinder heads towards the front of the engine near the camshaft phasers. The powertrain control module transmits a signal to the solenoids to move a valve spool that regulates the flow of oil to the phaser cavity. The phaser cavity changes the valve timing by rotating the camshaft slightly from its initial orientation, which results in the camshaft timing being advanced or retarded. The PCM adjusts the camshaft timing depending on factors such as engine load and RPM.
Ford bf fault code p1388
Hi there:DTC P1388 - Variable Cam Timing Overretarded (Bank #2)
Over-******** timing is detected. The PCM detected that the Variable Cam Timing "VCT" position indicated that the camshaft timing was over-******** when compared to a calibrated limit
Possible causes are::- Camshaft timing improperly set. - No oil flow to piston chamber. - VCT (variable cam timing) solenoid stuck open. - Camshaft advance mechanism binding (VCT unit).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
3helpful
Where is vct solenoid
Hi there:A code P0012 refers to the VVT (Variable Valve Timing) or VCT (Variable Camshaft Timing) components and the car's PCM (Powertrain Control Module, also called an ECM).
That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-********, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
A P0012 DTC trouble code may be caused by one or more of the following:
- Incorrect camshaft timing
- Wiring problems (harness/wiring) in intake timing control valve control solenoid system
- Continuous oil flow to VCT piston chamber
- Failed timing valve control solenoid (stuck open)
On Ford, the VCT solenoid is located at top of cylinder head underneath the valve cover and goes around one camshaft. You will need to remove the valve cover, the timing cover, then remove the timing belt, the camshaft sprockets, and finally the camshafts to remove the vct solenoid as it goes around the camshaft. You can use 2001-2003 models with same engine.
VCT or Variable Cam Timing solenoid is a device used in modern engines to change camshaft position timing in relevance to engine speed and engine timing allowing the engine to produce more horsepower without adding excessive overlap to the camshaft design.
The way the VCT Solenoid works is as follows:
The VCT solenoid works with oil pressure, it receives a signal from the ECM when the camshaft needs to be rotated either in the advanced mode or ******** mode depending on engine load and speed.The VCT solenoid is able to accomplish that by altering the oil flow in the passages that lead to the cam phaser(s), there are passages to advance the valve timing ( open the valves earlier), and passages that direct the oil to ****** the valve timing ( open them later)
The purpose of the VCT or Variable Cam Timing system is to allow the engine to move larger volumes of air in and out of the cylinders to generate maximum horsepower.
Vehicles with DOHC ( Dual Overhead Cam ) engines usually have two VCT solenoids mounted in each cylinder head, one for each camshaft, allowing the Engine Control Computer to activate each VCT timing mechanism in each Camshaft separately.
NOTE: The Cam phaser is mounted on the front of the camshaft(s) it is driven by the engine's timing chain or timing belt depending on the engine's design.
2helpful
P0012
P0012 - "A" Camshaft Position - Timing Over-******** (Bank 1)
OBD-II DTC Trouble Code Description
What does that mean?
A code P0012 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-********, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
Potential Symptoms
Most likely a P0012 DTC will result in one of the following:
hard starting
poor idle and/or
stalling
There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
Causes
Possible Solutions
The main thing to check is to verify the operation of the VCT solenoid. You're looking for a sticking or stuck VCt solenoid valve caused by contamination. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
EL VEHICULO TIENE PERDIDA DE POTENCIA Y EN EL SCANNER MUESTRA LOS CODIGO PO0011; PO0012
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
A code P0011 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0011 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
Potential Symptoms: Most likely a P0011 DTC will result in one of the following: hard starting, poor idle, and/or stalling. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
Causes: A P0011 DTC trouble code may be caused by one or more of the following:
Possible Solutions: This DTC code is a result of a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
P0012 - "A" Camshaft Position - Timing Over-Retarded (Bank 1)
A code P0012 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-retarded, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
Potential Symptoms: Most likely a P0012 DTC will result in one of the following:
hard starting
poor idle and/or
stalling
Causes: A P0012 DTC trouble code may be caused by one or more of the following:
Possible Solutions:
Hope this helps. Suerte.
1helpful
Have a code p0010 on my 06 ford fusion. where do i find it for bank 1. or what is causing it
P0010 - Intake Camshaft Position Actuator Circuit Open Bank 1
Possible Causes:
- Variable Camshaft Timing (VCT) position circuit is open or shorted
- Variable Camshaft Timing (VCT) position circuit poor electrical connection
- Faulty Variable Camshaft Timing (VCT) position solenoid
1helpful
I need to know how to set thte timing chain
Discoverd this indepth expalaination of process steps involved in the installation of the timing chain from an ASE certified technician. I hope this helps. See the repair manual on the link below.<br /> <br /> Link: <a href="http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html">http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html</a><br /> <table id="table14" style="BORDER-RIGHT: #000000 1px dashed; BORDER-TOP: #000000 1px dashed; BORDER-LEFT: #000000 1px dashed; BORDER-BOTTOM: #000000 1px dashed" bordercolordark="#000000" width="100%" bordercolorlight="#000000" border="0"> <tbody> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"><span class="name" roundtrip="0" lastvisited="3">By <a name="755408"></a><b roundtrip="0" lastvisited="0">Dave H</b>,<b> </b></span><span class="postdetails" roundtrip="0" lastvisited="0">Certified ASE Technician</span></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="100%" roundtrip="0" lastvisited="6"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-LEFT-WIDTH: 1px; BORDER-BOTTOM-WIDTH: 1px; BORDER-RIGHT-WIDTH: 1px"> </td> </tr> <tr> <td colspan="2"> <span class="postbody" roundtrip="0" lastvisited="77">PRIMARY TIMING CHAINS (NON-SUPERCHARGED) <br />NOTE:The 4.0L V8 has no engine timing alignment marks on the crankshaft or camshafts. Engine timing is achieved by installing the Crankshaft Setting Peg (303-531) and Camshaft Locking Tool (303-530). With the crankshaft setting peg in position, ensure the timing flat on each camshaft is in the uppermost position before installing camshaft locking tool. Variable camshaft timing unit may also be referred to as Variable Valve Timing (VVT) unit. <br /><br />NOTE:Special Tools Required: Crankshaft Setting Peg (303-531), Camshaft Locking Tool (303-530), Chain Tensioning Tool (303-532), Primary Chain Wedge (303-533) and Variable Camshaft Timing Oil Control Unit Setting Tool (303-654). See Fig. 232-Fig. 236 . <br /><br />NOTE:"A" bank refers to the right/passenger side of the vehicle and "B" bank refers to left/driver side of the vehicle. <br /><br />NOTE:Each door glass automatically drops 12 mm when the door is opened or when the convertible top is raised or lowered. It is important that windows are lowered before battery is disconnected to allow doors to shut properly. <br /><br />Removal ("A" Bank) <br />Tips Click a link to view tip <br />Tech1Tip: special tool <br /><br /><br />Remove timing cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). <br />Remove the variable camshaft timing oil control solenoid. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove the variable camshaft timing oil control unit housing retaining bolts and remove the variable camshaft timing oil control unit housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove and discard the variable camshaft timing oil control unit housing "O" rings. <br />Raise and support vehicle. Remove the bolt which secures the Crankshaft Position (CKP) sensor to the flywheel housing. Remove the CKP sensor and allow it to hang free under the engine. Remove the torque converter bolts access grommet from the flywheel housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Install the crankshaft damper bolt (old one) to the crankshaft, hand-tight only. Rotate crankshaft until the triangular arrow indent on the flywheel is visible through the access hole. See Fig. 144. Confirm that the timing flat on each camshaft is uppermost position. <br />Position the crankshaft so that the Crankshaft Setting Peg (303-531) engages fully into the timing slot. Install and tighten the bolt to secure the crankshaft setting peg. See Fig. 145. Remove the crankshaft damper bolt from the crankshaft and lower the vehicle. <br />Install the Camshaft Locking Tool (303-530) to the "A" bank camshafts, aligning the shafts slightly as necessary. Loosen the bolt that secures the exhaust camshaft sprocket and the bolt that secures the variable camshaft timing oil control unit. See Fig. 146. Remove camshaft locking tool. <br />Remove the primary chain tensioner bolts, primary chain tensioner and tensioner backing plate. See Fig. 147. <br />Remove the primary timing chain tensioner pivot bolt and remove the primary timing chain tensioner blade. See Fig. 148. <br />Remove the bolt which secures the primary timing chain guide. Noting the position of the primary timing chain guide, remove the primary timing chain guide from the upper retaining pin. See Fig. 149. <br />Remove the primary timing chain from the variable camshaft timing oil control unit and from the crankshaft sprocket. Clean and inspect all components. <br />Installation <br />If "B" bank timing chain was removed, see INSTALLATION. If not, go to next step. <br />If previously removed, install the timing chain sprocket to the crankshaft. The teeth of the "A" bank and the "B" bank timing chain sprockets on the crankshaft must be out of phase with each other. If they are in phase after installing, remove the sprocket, turn it on its vertical axis and reinstall sprocket. See Fig. 150. <br />Install the chain tensioning tool to the exhaust camshaft sprocket. Reposition the sprocket (and the variable camshaft timing oil control unit) for the most advantageous position for use of the tool. See Fig. 151. Remove the tool. <br />Install the primary timing chain into position over the crankshaft sprocket and the variable camshaft timing oil control unit. There must be no slack on the drive side of the primary timing chain and the sprockets must not be rotated on the camshafts, or the tensioning tool may not fit. See Fig. 152. <br />Install the primary timing chain tensioner blade to the cylinder block. See Fig. 148. Install the pivot bolt and tighten specification. See TORQUE SPECIFICATIONS. <br />Push the primary timing chain tensioner piston into the tensioner body to provide clearance for installing the primary timing chain. Insert a thin rigid wire through the hole in the end of the tensioner piston to displace the ball from the non-return valve seat. See Fig. 153. With the wire in position, press the piston fully into the tensioner body. Remove the wire. <br />Install the 2 primary timing chain tensioner bolts to the primary timing chain tensioner and locate the tensioner backing-plate on to the 2 bolts. Align and install the primary timing chain tensioner to the cylinder block and to the mating slot on the rear face of the primary timing chain tensioner blade. See Fig. 147. Tighten the primary timing chain tensioner bolts to specification. See TORQUE SPECIFICATIONS. <br />Use a Primary Chain Wedge (303-533), or 2 if needed, between the primary timing chain tensioner and primary timing chain tensioner blade, to take up the slack in the chain for tightening of the variable camshaft timing control unit and exhaust camshaft sprocket. See Fig. 154. <br />Using the chain tensioning tool, apply force to the tool in an counterclockwise direction to tension the chain on its drive side. See Fig. 151. While applying opposing force to the sprocket and chain, tighten the exhaust camshaft sprocket bolt to specification. See TORQUE SPECIFICATIONS. <br />Using the Variable Camshaft Timing Oil Control Unit Setting Tool (303-654), rotate the variable camshaft timing oil control unit fully counterclockwise to the fully retarded position. See Fig. 155. <br />Check that the primary chain wedges are still in place. While applying opposing force to the sprocket and chain using the chain tensioning tool, tighten the variable camshaft timing oil control unit bolt to specification. See TORQUE SPECIFICATIONS. Remove the chain tensioning tool and the primary chain wedges and camshaft locking tool. <br />Raise and support vehicle. Remove crankshaft setting peg. Install the CKP sensor and bolt to the flywheel housing. See Fig. 143. Tighten the CKP sensor bolt to specification. See TORQUE SPECIFICATIONS. Install the access grommet to the housing and lower the vehicle. <br />WARNING:Check that the ring dowels are engaged squarely. Fully locate the assembly as much as possible by hand. Failure to follow this procedure may result in damage to the vehicle. <br /><br />Install NEW "O" rings to the variable camshaft timing oil control unit housing. Lubricate the "O" rings and the bushing. Install the variable camshaft timing oil control unit housing. See Fig. 142. Install the variable camshaft timing oil control unit housing bolts. Tighten to specification. See TORQUE SPECIFICATIONS. <br />Install the variable camshaft timing oil control solenoid. See Fig. 141. Install and tighten the variable camshaft timing oil control solenoid bolt to specification. See TORQUE SPECIFICATIONS. <br />Install the timing chain cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). </span><br /></td></tr></tbody></table>
Top Hyundai Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
