(1) No need to know if engine block coolant drain plug was available. Once the water pump was removed, all engine block coolant was drained. (2) After removing the three engine mounting bracket bolts, I also removed the mount bracket from the the body and made enough room to replace the timing belt easier.
Fig. 1: Install a suitable engine support bar and attach it to the engine lifting eyes-1.8L and 1.9L engines
Fig. 2: Removing the front transaxle mount and bracket-1.8L and 1.9L engines
Fig. 1: Install a flywheel holding tool in a transaxle mounting hole on the engine, and engage the tooth of the tool into the flywheel ring gear
