No heat
SOURCE: maytag dryer MDG5500AWW will not
Could be any number of things .. igniter ( which lights the fire that dries your clothes) over-temp switches ( that disable the gas valve from opening and won't let a fire get started..) Defective gas valve.. not opening to let gas in for the fire that dries our clothes..
Those are the main components in your system and not much more I can provide to you unless I had specific details on what you've checked etc.. maybe this link will help identify the parts associated with your dryer... and if your so inclined..can do your own diagnostics... http://www.pcappliancerepair.com/model-display.php Hope that helps...
SOURCE: maytag mdg5500aww gas dryer sensor
First of all shut off the power by pulling out the plug.
If you are sure of the sensor issue then you need to remove four screws on the inside of the door. Two screws are located on the left and two on the right, look at the hinge and you will find two. The door will lift out when you remove the screws. When the screws are out of the front, the front panel can be remove by pulling on the outside surface.
SOURCE: Maytag dryer (model MDG5500AWW) will
Hi, If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. check out this electric no heat tip... heatman101
SOURCE: NO HEAT MDG5500AWW 56780829AX DRYER TURNS BUT NO
Maybe if you didn't borrow money from people you wouldn't have such bad luck
heatman101
heatman101
heatman101
