Refrigerators Logo
A
Anonymous Posted on Aug 23, 2014
What causes ice build up in bottom of freezer with french doors and then leaks out
What causes ice build up in bottom freezer of whirlpool French door refrigerator with two drawers - one for vegetables or large platters and one for freezer and water leaks out of bottom onto floor?
Jorgie Navito
Level 3:
Master:
  • Whirlpool Master 357 Answers
  • Posted on Feb 12, 2015
Jorgie Navito
Whirlpool Master
Level 3:
Master:
Answers
357
Questions
0
Helped
108941
Points
2245
Sounds to me like a bad door seals causing condensation and leakage
5 Related Answers
Avi
  • 66 Answers
  • Posted on Jan 29, 2011
SOURCE: Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Anonymous
  • 161 Answers
  • Posted on Jan 24, 2010
SOURCE: LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Anonymous
  • 117 Answers
  • Posted on Sep 28, 2010
SOURCE: I have a Samsung French
this may be of some help
Anonymous
  • 489 Answers
  • Posted on Jun 16, 2011
SOURCE: I have a samsung french
You may have a leaking water tank in the refrigerator and needs to be replaced.
Anonymous
  • 2047 Answers
  • Posted on Jul 20, 2011
SOURCE: My LG french door refrigerator
Preventing this could be quite tricky. But the best way to prevent this is to make sure you defrost the unit at regular intervals. Although the refrigerator part should have the defrost feature already in place but the freezer is normally expected to keep frozen goods so usually does not defrost automatically.
Also you can try to regulate the quantity of things which are put in the freezer segment as overloading the freezer could cause the problem you are experiencing.
Finally ensure that things which can generate water deposits at the bottom of the freezer are allowed to drain their water content before they are put in the freezer.
Once these are done you should not experience ice build up on the freezer door again.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Ice is forming under the freezer drawer what causes this
Clean your coils. Then defrost ice build up with a hair dryer. Good luck!
GX5FHTXVY04 slow leak in bottom of freezer.
Your Temperature Control for the Refridgerator is bad, once you fix it your problem will go away
2answers
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
New french door 27 cu ft....good performance for first two weeks...alarmed today by rapid dripping (for about 20 minutes) and puddle on floor in front of left front foot of unit. ...dripping stopped more...
The control board has a problem, we had the same problem and had the ice maker and control board replaced but we are starting to get ice building up under the ice bin. I'm very disappointed with this Whirlpool poduct.
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
