FREEZER RUNS 2 ABOVE WARM IN THE REFRIGERATOR
The problem is that the air is not able to circulate from the freezer to the refrigerator. Possibly a control door? Or, maybe the freezer is overloaded and blocking the air travel. I hope this helps!
Remove back cover in the freezer and check the evaporator fan motor. Also see ice patern. Possible defrost problem
SOURCE: We have a Samsung RB215LABB/XAA refrigerator - the
Well you need to unplug the machine and let it thaw out a day or 2. Then you gotta remove the service panel in the freezer. Then you need to check the heater or heater thermostat. Chances are one or both are kaput. The control might be bad but make sure the cheaper stuff is checked before committing to the more expensive control. I have a Samsung service manual. It might not be the exact one for your model but it will give a good idea what ya need to do. SAMSUNG
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Samsung RF263AEBP - Freezer and
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
SOURCE: samsung refrigerator model rs2545sh/xaa.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
SOURCE: My Samsung refrigerator freezer model RB1955SW is
My fridge turns on when it's plugged in but shuts off hours later for some reason and looses cool temp. I unplugged and plugged in the fridge again and it worked but shut off again hours later. What's with that?
Check the diverted box in fresh food side. Some of them have an electric flapper that opens to let cold air in to maintain temp in fresh food side. If coils are not frozen up then that is the next thing I would look at. The flap might not be opening up,
