My e65 730d has a lot of white smoke coming out of exhaust when engine has got up to normal temp. but has no smoke when is cold
SOURCE: I have a 95 BMW 740i V8. When ever i srep on the
White smoke means a coolant leak, check it and repair before to overheating your engine.
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Testimonial: "thanx ZJ. :-) Yea I read about some similar situations online yesterday here and other places. I appreciate your opinion and believe your right. i got some block sealer and will carefully follow its instructions. The process is to warm the engine till the heater is blowing warm air with the heater all the way up Only problem is my heater doesnt blow warm air only cold to luke. so ill have to assume its warm over the coarse of a few minutes. then shut the engine off and drain the radiator. then fill it with water again and again till its clear water then drain it empty. then with three quarts of water mix the block seal and dump it in the radiator and turn the car on immeadiately then etc as the instructions say. If this works I just scored a nice car for $800 and my white smokd problem will be gone"
SOURCE: My 320i takes longer to
Your head gasket is leaking and you'll have to take your car to your mechanic, the wihte smoke is coolant leaking into theengine cylinders, check you radiator it's problably low.
SOURCE: I Have lots of white
Check to see if the coolant level is low, if so you may have coolant going through the motor [ possible head gasket ]. If the level is ok, then you have condesation vaporizing from your exhaust system - some is normal.
SOURCE: citroen dispatch white smoke
That is bad news & a bad head gasket
White Smoke is coolant in exhaust
Why would you ask if that is normal?
Is that what you see following other vehicles?
