Konica Minolta Bizhub 362 Copier Logo
s
shahjhan mumtaz Posted on Aug 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monolta izhub 362 hwo to reset drum counter
Hwo to reset drum counter
San Diego Copier Repair
Level 2:
  • Expert 128 Answers
  • Posted on Aug 24, 2014
Expert
Level 2:
Answers
128
Questions
0
Helped
72310
Points
353
Bh 362 is the upgrade of Bh 200, 250 and 350 and on that model you need change drum and developer together. The drum counter message can be reset in service mode by a qualified tech after replacing those parts.
1 Related Answer
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Oct 27, 2011
SOURCE: Need to get computer to recognize driver for the
Insert the printer driver CD for bizhub 362 into CD ROM drive and run the setup utility.Read and follow the instructions on the screen.your pc will automatically detect the machine and install the drivers,Just use the printer driver cd if you do not have then download the driver from internet and install them.its quite simple.
Developer change
requires a tech to first clear counter remove the image install new drum cleaning blade and developer and run required porocedures
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to reset fusing in bizhub 363
go to service mode and in counters option clear the counter of fusing unit.it will reset.
1helpful
My konica Minolta buzhub 362 copier shows error 3452
Restart the machine.If code removes then its OK, otherwise press the utility/counter button and restart the machine.Don not leave the button.Keep the button pressed.Trouble reset will appear on screen hit it and restart the machine.
In Konica Minolta bizhub 362 it says ready to copy but I noticed it says "please change PC drum"
Thecopier has a counter the drum unit. "PC" means photo conductor, I don't remember if the copier will lock up if the drum unit is not replaced? There is a counter that needs to be reset once the drum & new developer is installed.
Need to get computer to recognize driver for the monolta 362. How do I do that?
1helpful
Change PC Drum Message on Bizhub362.How do you resset this message?
You are going to need to call your service company and have them replace the drum unit for you. Don't listen to anyone that gives you the service mode entry procedure and drum count reset. This WILL screw up the AIDC (Automatic Image Density Control) and the machine will shut down with a COF32 code. There is a very specific procedure which must be followed when replacing/resetting the drum counter on these machines as there are several "counts" that are tied together. Trust me on this as a 27 year Minolta Tech, spend the money and have the drum unit replaced. They are good for 100,000 copies so even tho it may cost some money to do. Divide that cost by 100,000 pages and it gets pretty cheap.
Good Luck and Thank You for using Fixya.
3helpful
How can I cut off the annoying beeping sound on the bizhub 362?
Press utility/counter button.on panelPress user settings.on touch screenNow check all the tabs.in one tab you will see the volume option for beep sound.decrease the volume and press ok and then press reset button.its done.
5helpful
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
11helpful
2answers
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
24helpful
2answers
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
