Garden Logo
J
Jason Snow Posted on Aug 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
John deere tractor model 145 won't go into gear
Model 145
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • John Deere Master 1,917 Answers
  • Posted on Aug 30, 2014
charles beach
John Deere Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
569692
Points
3010
Hydrostatic pump bad replce it about 200.00
5 Related Answers
Anonymous
  • 548 Answers
  • Posted on Aug 22, 2009
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Anonymous
  • 1627 Answers
  • Posted on Nov 10, 2009
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Rocky Ridge Mowers
  • 71 Answers
  • Posted on Jan 08, 2010
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 13, 2010
SOURCE: looking for a free download for a john deere model 650 owner's ma
http://www.ssbtractor.com/tractors.cgi?m=john_deere
www.deere.com/en_IN/home.../OMPY0146_19_22AUG06.pdf www.tractorbooks.co.nz/Tractor%20Manuals.pdf
Mike Squire
  • 420 Answers
  • Posted on Jun 02, 2010
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
2answers
Firing order for my John Deere 3020 gas tractor?
Edited text with a wild guess at the maker. Make model (what it is) in all questions please.
Category moved to John Deere Tractor.
If it was working before, there is no need to worry about the firing order as that never changes. Things to look at;
Clean and correctly gapped spark plugs,
Clean gas,
Fuel filter?
and a clean carburetor, float bowl and jets.
John Deere 3020 Engine Engine Detail John Deere Firing order: Starter volts: Oil capacity: 9 qts 8.5 L 13 more rows
Jul. 10, 2020
TractorData.com John Deere 3020 tractor engine information
John Deere 3020 Tractor Service Manual - Jensales
https://www.jensales.com > products > John-Deere-302...
This John Deere model 3020 Gas and Diesel Tractor Service Manual is a digitally enhanced reproduction of the original manufacturer-issued Shop Manual.
US$120.98 · ‎In stock
operators manual for john deere 3020 tractor owners ... - eBay
https://www.ebay.com > itm
3020 Tractor Operators Manual. This operators manual includes Gas, Diesel, Lp. This comprehensive manual includes. Fully Covers Serial No.
US$15.97 · ‎In stock
JOHN DEERE 3020 Gas and Diesel Tractor Service Manual
https://www.ebay.com > itm > JOHN-DEERE-3020-Gas...
This is a new reprint of John Deere Service Manual SM2041 for the John Deere 3000 Series Tractors shown above. It is dated June 1961. Includes 3010 & 3020.
I have a John Deere LA 145 lawn tractor. It won't move? Drive belt changed, key in wheel, and clutch pin pushed in, ideas
https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DjMeJm9OIJcI&ved=2ahUKEwiHjZn4nP7pAhX4TDABHWZICQ8QwqsBMAh6BAgFEBA&usg=AOvVaw2_QquLuKI8KVwFivpPuhR5&cshid=1592032037932
Different model but same transaxle.
125 electrical drawings
Here's the link and I'm sure you will get the solution of your problem.
John Deere 102 115 125 135 145 155C 190C Lawn Garden Tractor Technical...
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
JOHN DEERE LAWN TRACTOR 145 SERIES, RUNS OK
When you start to have this problem loosen the fuel cap and see if that makes any differance,there is a small vent hole in the cap that can get plugged.When it gets plugged your fuel tank will develop a vaccum and cause you engine to starve for fuel.Im not sure on this model but the older 100 series had a problem with the fuel line being pinched between the frame and the tank.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
