Try this, hold down the power button, and the
Volume down buttons at the same time. Keep holding
Until you see a 3d android, lying on it's side.
Then use the volume down button, scroll down to either,
system reboot. Or factory reset ( if you have an SD card in, take it out first)
The reboot will just reboot your tablet, and it should
Turn on and fix the problem.
the factory reset, will erase everything in the system.
If it ran alight before, and you had stuff saved to the
Tablet, it will erase it also. I'm sorry but it can't be saved.
so make sure your SD card is not in.it will erase it too.
The factory reset will restore the tablets settings, and reboot. But only do this as a last resort. Hope this helps
