Search engine results navigation
Add &start=
to the end of the url and enter the result you want to start at. usually its the page number multiplied by ten and then subtract ten from that for example page 8 for a search result for google, https://www.google.com/?q=google&start=70
SOURCE: google chrome can't browse any sort of page there
There are many things that we need to consider regarding the issue. Let's just hope that it's not virus related.
Try the ff:
- Close Google Chrome.
- Go to Start> Control panel> Click Internet options (make sure you select Classic View on the left side). It's going to open Internet Properties. Go to Connections Tab> select LAN settings > uncheck Use Proxy Server or just check Automatically detect settings and then hit OK.
Then try opening Chrome to see if it works.
You can also try using Firefox to see if it's also happening there. If it does, then check your internet connection because it's not a Browser issue and it could be something else.
SOURCE: when using google search engine, after attaining
perhaps there's some issue with your system registry so you should use Reginout cleaner to fix this issue
SOURCE: How can i remove movs search engine that keeps
Click on the Spanner Symbol on the top right handside to 'Customize and Control Google Chrome' -> select 'Options' -> Change 'Home page' URL for 'Open this page' to what you want or to just 'about:blank' (without the quotes).
You can also modify your 'Search' engine default on that same 'Options' page.
Hope it helps!
MyStart by Incredibar is a browser ******** that will alter Internet browser settings on the infected computer. This threat also drops certain files and registry entries that are essential to complete its tasks.
Typically, MyStart will enter the computer through other programs or freeware that you may download from third-party provider. The adware will get installed without your consent while loading the desired program.
To Remove it Follow the Following Steps.
Click on wrench (upper right hand of page)
Click on "Settings"
Click on "Extensions" (upper left of page)
there will be a list of active extensions. I would suggest deleting it rather than disabling.
Hope It'll work for you.:))
Prior ascertain that the computer devices are network structure established. For example with computers, an internet connection either dial up line or wireless, broadband prior connectivity is required to make website features attainable. In situations that computer structures least has been provided network connectivity least displays yahoo resources either web pages or mail features. Computers that have been provided internet connectivity experiencing malfunctions either requires retracing the features that produces malfunction prior to requesting website experiences. For example, ascertain the computers line connections display as functioning to attain sites. Usually with computers that have internet connectivity would also have web browser programs from where navigation is attained from user. For example, once powered on networked computers, click display a program internet explorer, Google, or yahoo that makes features attainable. The browser program display areas as search spaces from where requested media is request able. For example, the areas on the page that type searched results are requested is made available from the browser program.
