I turn the key on the scooter starts no problem I move down the road the power to the throttle stops I then give the scooter some throttle it moves on then stops again on its own. The battries are still charged. What is the cause of the short
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
SOURCE: lil rascal stopped again
make sure you hands are not touching the forward or reverse lever when you insert the key. many times if you have your finger or thumb touching the lever just a tid, the scooter will only move a little then stop, or not work at all. this is a safty. Usally I change out the throttle pot and the Key switch (speed pot) together. As for the price, He didn't over charge you if the 150.00 included his labor. Ask if he can replace the throttle if the product is less then 30 days old. But be prepaird to pay shipping and his labor for replacing the first one.
SOURCE: the battery is fully charged but the scooter will not move.
Is it the small portable scooter? The one with the base that comes apart for transporting? Could it be a bad connection where it goes back together?
If it is the portable, try disconnecting the rear drive portion from the base and re-installing it so it clicks into place.
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
