If you're not getting fire to the spark plugs after changing the coil pack, it could be due to a few different issues: Faulty new coil pack: It's possible that the new coil pack you installed is faulty or not compatible with your vehicle. Double-check the specifications of the coil pack and make sure it's the correct one for your make and model. Faulty spark plugs: If the spark plugs were not replaced along with the coil pack, they could be worn or damaged and not firing properly. Check the condition of the spark plugs and replace them if necessary. Wiring issues: There could be a problem with the wiring or connections between the coil pack and the spark plugs. Check all of the wiring and connections to make sure they're secure and free of damage or corrosion. Bad ignition control module: The ignition control module (ICM) controls the timing of the spark and sends a signal to the coil pack to fire. If the ICM is faulty, it could prevent the spark plugs from firing. Check the ICM for any signs of damage or wear, and replace it if necessary. Faulty crankshaft position sensor: The crankshaft position sensor tells the computer when to fire the spark plugs. If the sensor is faulty, it could prevent the spark plugs from firing. Check the sensor for any signs of damage or wear, and replace it if necessary. If you've checked all of the above and still can't find the problem, it may be best to take your vehicle to a mechanic or dealership for further diagnosis and repair.
