SD cards max out at 2GB. SDHC cards go up to 32GB and SDXC cards go up from 64GB, but they will work only in devices designed for them. If your camera's specs mention only SD cards then the higher-capacity cards won't work.
The A520 uses SD cards. SD cards max out at 2GB in size. A microSD card in an adapter looks exactly like a SD card to the camera, and microSD cards also max out at 2GB. Anything larger is a SDHC or microSDHC card. While they will fit into the slot, they are electronically incompatible and will not work. So, the short answer is: 2GB.
The maximum size of SD cards you can use is 2GB since SD cards max out there. SDHC cards max out at 32GB. The camera itself does not impose any limits on those two types. In short, you can use any SD/SDHC card.
The Z760 uses SD cards, which max out at 2GB. Larger cards are actually SDHC cards (the HC stands for High Capacity). While SDHC cards will fit into SD slots, they will not work.
