Vicks V3100 1.2 Gallon Humidifier Logo
Posted on Jul 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New filter,still no mist and water level does not drop
My machine is two weeks old needed new filter replaced cleaned as to the manual still no results.any ideas please?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 10, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1820
Points
5
Make sure that the filter is VERY snug into the bottom of the humidifier, and that the tank is on correctly. We had the same problem :)
Anonymous
Level 2:
  • Expert 114 Answers
  • Posted on Aug 20, 2009
Anonymous
Expert
Level 2:
Answers
114
Questions
0
Helped
81768
Points
184
Part of the reason why you don't see any mist is because it's a cool mist humidifier. normally all cool mists do not produce that moisture that you would see in a warm mist unit. if you have any other concerns about the product please feel free to ask.
Mainstays Cool Mist Humidifier 1 gal MDH-0103JW Low Tank Indicator Auto Off NEW Manual
Here are the instructions for the Mainstays Cool Mist Humidifier 1 gal MDH-0103JW:
  1. Remove the water tank by lifting it straight up and off the base.
  2. Turn the water tank over and remove the tank cap by turning it counterclockwise.
  3. Fill the tank with cool water and replace the cap by turning it clockwise.
  4. Place the tank back onto the base, making sure it is seated securely.
  5. Plug the humidifier into an electrical outlet.
  6. Press the power button to turn on the humidifier. The power light will illuminate.
  7. Press the mist button to select the desired mist output level.
  8. The humidifier will automatically shut off when the water level in the tank is low.
  9. To refill the tank, repeat steps 1-4.
Note: For optimal performance, it is recommended to clean the humidifier weekly. Please refer to the user manual for detailed cleaning instructions.
Nov 06, 2022 • Humidifiers
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
Hello FREIDA GRAYDEN,
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
HAPPY FREIDA (I think).
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
expect YOU to be TOTALLY SATISFIED.
Carnac the Magnificent
https://www.amazon.com/HoMedics-Cool-Mist-Ultrasonic-Humidifier/dp/B00EW1QJPS/ref=pd_sbs_201_2?_encoding=UTF8&pd_rd_i=B00EW1QJPS&pd_rd_r=S79PF7TS0FVV4D24Y2GP&pd_rd_w=jrPo2&pd_rd_wg=POkzf&psc=1&refRID=S79PF7TS0FVV4D24Y2GP
Jan 11, 2018 • Humidifiers
Why does my humidifiers does not have any smoke coming out?
My Guess is that the reletive humidity in the room is not low enough to see any vapors coming from the machine. Normaly you won't see these anyway. Some models in the stores seem to make more mist than what you get at home. If the humididty level in a room is close to what is coming out of the machine there will be no signs of any mist coming out. Just make sure the filters are clean and check and make sure the water level is going down on the machine and this will tell you its workin. the faster you are using the water in the tank the more you are putting in the air! If this is a hot mist machine then I would say the heating element in the machine is not working.
2helpful
2answers
I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Fan works, but no mist and water isn't going away
Turn on furnace and urn up humidistst to call for it. Tube from solenid to the filter should have water running if water is up to the valve and solinoid is opening . It should be warm to your touch., Using an ohm meter you can sheck the coil it shuold have continuity.
Iron/rust in water
You can use distilled water to fill your humidifier that would save your filters.
Or you can try soaking your filter in a 50-50 water and white vinegar solution to try and clean them to use again.
Good Luck.
1helpful
2answers
Fan runs but no moisture
According to the manual, there may be a problem with your water level sensor. According to the manual:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
I scanned in the page from the manual that shows how to dismantle, clean, and reassemble the water level sensor here.
If that doesn't work, you can try contacting the manufacturer:
Dart Warehouse Corporation
Tel: 1-888-599-0992 (Mon-Fri 9:00 AM - 4:00 PM Central)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
1helpful
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
