I can fax out, I have dial tone. But when I try to send it a fax from work it says no answer. Fax is on Fax only mode
SOURCE: wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
SOURCE: We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
SOURCE: receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
SOURCE: Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
