Question about Nortel 1110e 1120e 1140e 1200 1210 1220 1230 Ip Phone Handset Graphite Gray
Why won't my headset work - Nortel 1110e 1120e 1140e 1200 1210 1220 1230 Ip Phone Handset Graphite Gray
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Oct 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
When I try to charge my headset, the indicator light flashes red instead of staying solid. Please help me, I love this headset and I'm so upset it won't work for me..
If this is not charging correctly it may be that the battery is no longer functioning properly. The batteries are non replaceable on this headset. If this is still under warranty (1year) you should be able to get a replacement
Here is a link to the User's Guide.
Aug 30, 2011 | Plantronics M100 Bluetooth Headset
CS55 headset battery was dead (app 1 1/2 years of service). I replaced it and fully charged. Worked fine for 3 or 4 days. Now, won't charge. Tried the system reset and power cycle, no...
On your base there are the numbers 1-4. Put the # 1 in the 3 O'Clock position like a clock. Try putting the letters that are in the bottom on B.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics CS55 Wireless Headset
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
May 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics 220 won't turn off. The blue light won't turn off and I can't get it on or off.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Here is the link for the Plantronics 220 User's Guide.
May 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
The handset lifter works, but no sound can be heard or received by either party
If you have a 510a base, then purchased a Plantronics Voyager Pro headset to replace your old headset, it won't work. Those are two different headsets. The Voyager Pro is not meant to work with the 510a base. The correct headset is this:
Plantronics Voyager 510 Replacement Headset
Jan 27, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Just need a printable manual
here is the pdf of it.
http://www.greennet.ca/ebay/Explorer220_PLN-7551601/explorer220_datasheet_en.pdf
if it doesn't work try going here.
http://phone.manualsonline.com/manuals/mfg/plantronics/220.html
Then click on "get this manual" and when a window pops up click "skip special offers"
Jul 02, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Headset mic won't work.
What have you done to try to fix it I need to know so I can help you fix it and Mabry you need new headsets
Nov 18, 2017 | Logitech (980158) Headset
New ps3 headset won' t work
like my headset was fully charged and i got grounded then it wouldnt work when i got my ps3 back if you have had the same problem shoot me a email at matt.hardy68@yahoo.com if you have fixed it tell me out
Nov 09, 2008 | Mad Catz PS3 Bluetooth® Headset Wireless...
Plantronics 330 bluetooth headset / Nextel Blackberry 7100i performance
After looking through the phones, there many possibilities, wow quite a few. It does not have any recommendations on headsets. The headset is only as good as the the quality you are purchasing. If your phone drops calls it won't be from the bluetooth device. Below is a link to the Explorer Series 300 User's Guide, which may help you.
Plantronics Explorer Series 300 User's Guide
Sep 22, 2008 | Plantronics Explorer 330 Headset
Nortel 1110e 1120e 1140e 1200 1210 1220 1230 Ip Phone Handset Graphite Gray Logo
29 people viewed this question
Top Nortel Radio Communications Experts
ka4iup
ka4iup
Norm Pearl
Harrie
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
